Question about Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP HLR5667W has blinking squares at startup
I have a Samsug 56 DLP HLR5667W that has recently displayed blinking green, red, yellow squares across the screen at an angle when I turn the tv ON (the picture is relatively clear and the color is good). This only occurs when I have the tv switched to antenna input - If I switch to the cable iput - I can't even see a picture, the screen displays (5) multi-colored vertical lines and a variety of wide/narrow horizontal bands. If I pull the 120 V plug on the tv for a reset - sometimes it comes back on clear with no issues and other times it doesn't. This only occurs when I turn the tv ON. If it starts that way - it stays in that mode
  • toroisn1 Apr 02, 2009
    same here I hope by posting this it will kick up some answers.
    thank you for any and all help you have.
  • tom_rayma Apr 11, 2009
    I have the same problem the picture looks good until I turn on the Direct TV then it turns into an Irish plaid quilting pattern. You can still see a picture, but it is very hard to see. Picture frames are frozen and if you want to see the picture you have to turn on the PIP control screen to see it clearly. I used to be able to unplug and plug the TV back in and the problem would correct itself, but now that is not working either. I am thinking it has to do something with the filtering process on the TV from any cable/satilite hook up. I do not experience the problem until the satilite/dish is on. I have had this problem for about a year now.
tvtechnician
  • 105 Answers
SOURCE: dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Posted on Oct 24, 2007
jerryg50
  • 1689 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
  • 4234 Answers
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
Posted on Aug 28, 2008
  • 453 Answers
SOURCE: dlp
most likely a bad optical block part price between $450 - 550
Posted on May 02, 2009
SOURCE: adjusting color after color wheel replacement samsung dlp tv
There should be a jumper somewhere around the color wheel. I am having a problem with my color wheel, and after doing a lot of research I found that people that have the same problem as you changed the jumper setting. Try looking it up here on the net. Should solve your problem.
Posted on May 24, 2009
Samsung HLR5667W 56-Inch DLP HD TV not working
A black and white picture usually indicates the color wheel has failed or the DMD board has failed. Call 1-800-samsung to find neaREST SERVICE CENTER.
Jun 16, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
Feb 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung HLR5667W DLP won't come on. Lamp lite blinking
Feel better now?
Tried a new lamp or is it now very old and damaged the main board?
Sep 20, 2017 | Samsung HLR5667W 56" Rear Projection HDTV
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Pic freezes, goes dark w/sound then back on
By what you have said your color wheel can cause this when it stops running .Pull back off and watch what is happening when you turn set on.
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
Distrorted Picture on all Analog Channels, HDMI and PIP Picture is fine.
Sounds like a bad DLP chip and they will prob end up replacing the light engine in the set most people dont like replacing this part. Hopefully they get you up and running.
Jan 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
111 people viewed this question
Jerry Greenberg
Jerry Greenberg
