May i know, is it a crt monitor or lcd monitor? If it is a crt monitor, then you can try to check the dry joint on te pcb board especially primary and secondary power supply. After that check the FBT with blue ring tester & cap meter to check their HV cap value.
If it is a LCD Monitor, please check on inverter board and the ccfl lamp too. Please check all the electrolytic cap on lcd monitor pcb board for low esr ohm with blue esr meter. Below is some usefull link for repair lcd monitor and crt monitor:
I just hooked up a new computer to the old monitor and I read out of range. It displayed the boot...
(More)
I just hooked up a new computer to the old monitor and I read out of range. It displayed the boot I'm sequence and windows loading but then displayed the error last
black spot of the size of a ping pong ball on my screen appeared overnight wat mght be...
(More)
black spot of the size of a ping pong ball on my screen appeared overnight wat mght be the problem its a phillips 17 inch lcd monitor
like they said, ping pong ball sized spot in lower right corner, appears to be growing, and a few areas at the lower edge of the screen are losing color, plus if you touch the screen there, it has a "ripple effect". Mine is a Hanns-G 19" widescreen
black round spot at the bottom of screen laft hand side - AOPEN monitor 17"
