Question about Lexmark Office Equipment & Supplies
My fax machine/printer is saying i have a paper jam. there is no paper jam. i am looking in and throughout this machine. i need to print important papers on a daily basis. i need my machine fixed or a replacement. thanks.
    Sergeant:
    Champion:
  • 274 Answers
Normally the machines are right about paper jams, no matter how small a piece of paper it is.
Check in feeder tray, open all doors, look under rollers....etc.
Posted on Nov 19, 2008
After fixing a paper jam, my printer will not print or scan from the computer. Say computer not found. what do i do?
while on jamming the machine the USB cable may have come on plugged check that first.be sure not only to check where it goes into the computer but more importantly where it went into the printer.if that doesn't work try rebooting both devices.
Jul 17, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Mar 28, 2012 | Samsung SF-5100 Plain Paper Laser Fax
Won't let me fax, copy or print. it tells me paper jam 2 look in
paper jam 2 generally denotes the fuser unit. thats at the back, the bit that heats up, theres a flip up/down cover that once opened should show you if theres any paper in there, also check the sensor, little black arm, move freely and be sprung, if the sensor is missaligned it will denote a paper jam even when there is none be careful to let the fuser cool down, printer unplugged for 10 minutes or so, 180 degrees will hurt.
Sep 24, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Hi, i am getting a rec paper jam message, I replace clutch, pu roller, solenoid and sep pad on tray 2 this is a Canon LC 2060
Hi
1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
3. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
4. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
5. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
6. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
7. Plug the printer’s power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Canon LaserClass 2060P Plain Paper Fax
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
Canon MF4100 Series UFRII LT has paper jam after i accidentally turned off the printer while it was int he middle of printing. The LED screen on the printer says "Paper Jam" then "Lift panel to open open...
just press the resume button and if the problem presist switch off your printer and computer and again restart both of them. and if still paper jam then press resume button.
Feb 27, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
My printer/fax machine will not print. it is saying to remove a paper jam. there is no paper jam. i have followed the steps as far as turning it off and back on plus i hit the check button and still...
Was there a paper jam just prior to this problem occurring? If so, look for any small pieces of paper that might be causing a jam. This may take a flashlight, and a close inspection of the entire paper path. This type of error generally occurs when the paper path is being blocked, or the paper can not move to the proper registration point ( ready position ) in the printer.
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Unable to initialize
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Paper jams in Lexmark X4270
Mine is doing the exact same thing and I need to know how to fix it, I am expecting some very important paperwork and I need the fax machine working!
Aug 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
