Question about Miele 24 in. G665 Built-in Dishwasher
Shutdown of DW very near end of drying cycle
Very near the end of the drying cycle, the DW appears to have tripped a circuit breaker (not Earth leakage trip). After untripping the breaker, the DW does not indicate any power to the device and so no longer operates. Is there a fuse on these machines that might also have blown? If so where is it and how do I replace it? I have seen the responses about water leakages causing Earth leakage trip outs, but this does not appear to have happened in this case.
  • Vaughan Roberts Dec 14, 2006
    OK, I got the repair man around and the LED circuit board had blown and taken the door close sensor switch out with it. We have a working DW again.
  • 21 Answers
Good to hear that you got this fixed.
Posted on Jun 10, 2008
I have a Bosch SGS4002au/20 dishwasher and recently just at the end of the cycle when drying, the 20A circuit breaker servicing the power point for the dishwasher trips
Sounds like a faulty heating element or NTC. Remove right hand side panel and look for water leaks near heat box. Try a multi meter on heating element and make sure it’s not shorting.
Dec 28, 2017 | Bosch Dishwashers
Hotpoint Aquarius wm61 trips as soon as its filled with water,if I remove alot of the water it will allow me to spin
If you mean that the machine is tripping the circuit breaker then that is an indication that the water is creating an electrical current path to Earth. The heating element is normally enclosed in a metal sheath but if this is compromised then water will get in and current will then leak to earth, causing the circuit breaker to trip. The heating element can be replaced, but the cause of the damage to the element should also be determined to prevent it happening again. The rotating drum can become partially detached from it's mount and end up hitting the heating element when spinning, causing the element to be damaged. The drum mount (often called a SPIDER) may therefore also need replacing. If you machine was making a lot of knocking noises when in spin cycle then it would certainly indicate a broken mount.
Feb 08, 2016 | Hotpoint Washing Machines
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Tripping the breaker
How far into the cycle does it trip the breaker?Does the motor run then trip it?Is it at the end of the cycle when it goes to a dry cycle?Does it trip in the beginning when it fill's up with water?
Mar 19, 2009 | Dishwashers
Seem to have an earth fault with a prima lpr 450 dishwasher runs for about 15 min then trips our electric.It did a few times from new (about 3 years old now) then stopped doing it, now does it nearly every...
Hello gcsounds,
If I understand your problem correctly, it appears that you have a ground fault ( or earth fault) that is causing your breaker to trip. I am assuming ( but don't know for sure ) that your dishwasher is hard wired into a junction box and that junction box is fed power from your circuit breaker panel. I am also assuming that the circuit breaker is either a Ground Fault Interupt ( GFI ) or standard type and that breaker is what you are saying is tripping with every wash cycle. There are some details that need to be filled in for me by you in order for me to fully understand your wiring scheme and suggest ways to resolve your problem. First off, can you provide details on how your dishwasher is wired ( as I suggested above or other) and secondly, what voltage are you running it at? If you are in the US then in all probability you are running your dishwasher at 120VAC @ 60 hz but if you aren't then please elaborate. Once I have that information, I may be able to assist diagnosing and resolving your problem.
Regards,
Rick
Nov 22, 2008 | Dishwashers
Dishwasher power overload
Check heating element in DW and all parts associated with it located on the inside of DW under the spray arm. It could also be a problem with the control panel,Call technician.
Dec 09, 2007 | Dishwashers
DW trips cicuit breaker
I have seen a lot of these older dishwasher break the wires running up to the timer. the break right near the bottom of the door where they flex when you open and close it. I would turn of the power, remove all the torx screws along the inside edges of the door, as well as the 2 on the bottom edge of the door facing up (you cant see them, just gotta feel around for them) and loosen the 2 on the top of the door near the latch ( so you can tilt the control panel out to remove the outer door) follow the wires from the timer down to the bottom of the door and see if any are broken or missing insulation. If not, take the bottom panel of the dishwasher as well and locate the 2 terminals hooked to the heater and check them with an ohmeter to see if they are grounded to the frame of the dishwasher. the dishwasher may be doing a heated rinse just before the dry cycle even though you have low temperature and no heated dry selected, so the problem may still be the heater. Good Luck!
Dec 12, 2006 | Asko 1385 Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
826 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
