Numbers are locked - will not unlock
The numbers print characters and the characters print numbers
RJ
Not a solution! I am 84 years old and cannot afford to invest any more money in your equipment that has let me down. I had the same problem on a LapTop and by holding down the Fn and scroll keys it was solved. Will you help me or not? RJ
Posted on Nov 19, 2008
How do you erase the memory on a renualt key
ok here we go...... inside the key there is numbers. keys with 5 or 7 characters can only be programmed using diagnostic equipment. keys with 8 characters as follows
ign off, press central door locking button for more than 5 seconds
NOTE: doors should lock then unlock. in other words pull the button up and down.
carry out the following within 10 - 15 seconds
press first key lock/unlock button twice (some models once)
press second key lock/unlock button twice (some models once)
hope i helped
Jan 07, 2012 | Cadillac DeVille Cars & Trucks
When my number lock is on the letters will not print as stated they will print a number or other
This is normal for a keyboard with embedded number pad, rather than a separate 10-key area. Turn off the number lock to type the alphabetical characters and use the top row of numbers to enter values. Turn on the number lock when entering only a long string of numbers.
Alternatively, connect a USB external keyboard to the notebook. Either get a large keyboard with a separate number pad or get a 10-keypad only (http://www.cyberguys.com/product-details/?productid=37379 ). Then you can have a normal keyboard and stil have the 10-key functions without toggling the NumLock often.
I hope this helps.
Jun 11, 2011 | HP Pavilion DV9620US Notebook
Asus X58Cseries with Windows Vista Basic has $ sign on 4 key but no pound sign. Any way of getting it? If not, I can live with it but would like to know either way.Cheers, Linda.
I'm an Asus X58C user in the UK and my keyboard is the same. I've not found an easy solution. The only way I can insert a £ character is this. Place your coursor where you want the character. Turn Numbers Lock on using the blue Fn and NumLk keys. Hold down the Alt key and then using the blue numbers keys type 0163. Release the Alt key and the £ character will appear. Turn Numbers Lock off using the blue Fn and NumLk keys again. Its laborious but it works, its how I typed it here. I also found out that if you hold down Ctrl and Alt and then press the 4 key, you type the euro character €. Hope this helps
Oct 06, 2009 | ASUS 90-A4C1K1000 Keyboard
As I input characters - letters, it prints out
Go to Preferences, then general, then Digitizer.
You need to recalibrate the digitizer.
It will ask you to tap in two opposite corners, then at a target in the center of the screen.
Should fix you right up
Aug 08, 2009 | Palm Z22 Handheld
Wheelwriter II characters above the numbers print incorrect.
You may have an unusual printwheel that has special char. on the P/W, or you may be in the language mode hold code and press "L" key.
DickyO
Mar 10, 2009 | Lexmark Wheelwriter 3 Typewriter
Help me
this the code for your problem. by the way this for vb6.0
Sub CountCharacters(Text As String)
Dim iVowel As Integer
Dim iCons As Integer
Dim iNum As Integer
Dim iSpace As Integer
Dim iOther As Integer
Dim cnt As Integer
Dim sChar As String
For cnt = 1 To Len(Text)
sChar = LCase(Mid(Text, cnt, 1))
Select Case sChar
Case "a", "e", "i", "o", "u" ' And sometimes "y"?
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
' Includes the first case, but VB matches the first case and stops
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
Case " ", vbTab, vbLf
' Space characters
' Not including vbCr as this will likely be dealing with Windows text
' and I only want to match one character for a newline
iSpace = iSpace + 1
Case Else
If sChar <> vbCr Then iOther = iOther + 1
End Select
Next cnt
Debug.Print "Text: " & Text
Debug.Print "Vowels: " & CStr(iVowel)
Debug.Print "Consonants: " & CStr(iCons)
Debug.Print "Numbers: " & CStr(iNum)
Debug.Print "Space characters: " & CStr(iSpace)
Debug.Print "Other: " & CStr(iOther)
End Sub
Feb 21, 2008 | Computers & Internet
Help me
Dim iNum As Integer
Dim cnt As Integer
Dim sChar As String
Select Case sChar
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
' Space characters
iSpace = iSpace + 1
Case Else
End Select
Next cnt
End Sub
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
