Question about Canon PowerShot A430 Digital Camera
Canon camera won't hold it's charge
I have a Canon A430 and no matter what new batteries I install it just keeps telling me to insert new batteries. Have had camera about 2 years without much use. Any suggestions?
  • 1 more comment
  • Anonymous Jan 05, 2009
    me too facing the same prob
  • gibifiu Jan 24, 2009
    Hi!
    I have the same problem. I wanted to solve it with changing the small (CR1220) battery, but the problem still exists.
  • Anonymous Mar 06, 2009
    Its just that it wont accept any other non-rechargable batteries which sucks...what if you mis place your chargeable batteries and want to use the camera ? NO ? then sucks
Hello!
I think I found the soultion.
So when the camera shows that changing battery is needed take those batteries to a discman or hand lamp or any other tool to exhaust the batteries completely. It's necessary becasue the camera can't do it and some charge can remain in the batteries and recharging them in this state leads the batteries to go wrong. So charge them after a total exhaust!
This worked for me.
Peace!
Posted on Jan 27, 2009
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
No matter what batteries I put in the camera it still tells me to change the batteries
Try to look in the bottom of battery box. It may be stain or even worse, somebody was used before a couple of ordinary zinc battery that may leak. Try to clean any rusty spots with alcohol and a bit of paper towell, and try again. All metal parts must be clean and shiny.Insert only rechargeable Duracell or other type battery if possible.
Sep 17, 2010 | Canon PowerShot A430 Digital Camera
Camera keep on displating
OK try using some steel wool or emery paper (fine) on the terminals inside the batteryy compartement. I suspect there is some sort of corrosion or substance causing poor connection.
Hold the camera so no swarf gets retained in the battery compaertment. Wipe the area clean after rubbing contacts
please rate my help++++Thanks for using FIXYA
May 07, 2010 | Canon PowerShot A430 Digital Camera
Battery problem?
i have this excact same camera ... happened to me... it will work after a little bit, open battery door and let sit for 3 days, other wise turn screen off
Oct 21, 2009 | Canon PowerShot A430 Digital Camera
Canon powershot A430 says batteries need changing constantly
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation. Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 15, 2009 | Canon PowerShot A430 Digital Camera
Canon Powershot A430 - can i charge batteries through AC
The A430 is a camera, not a battery charger. If you want to use rechargeable batteries then you must use a separate charger. Battery chargers should be available at just about any department, electronics, or office-supply store.
Apr 30, 2009 | Canon PowerShot A430 Digital Camera
CANON PowerShot A430 4.0mp Digital Camera eating batteries
The A430 is a 2 battery camera, and is known for being power hungry. Alkaline batteries just don't have the power for more than a few pictures in a digital camera (especially a 2 battery camera). Lithiums can also have problems. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation. Modern NiMH batteries have over five times the energy concentration of the average alkaline (yep over five times more power!).
Jan 18, 2009 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 won´t start
get a bucket full of water, with a little bit of dreft. gently wash your camera; if this does not work, call thomas the camera-repair guy: he has 5 years of online-camera-repair-experience.
Aug 28, 2008 | Canon PowerShot A430 Digital Camera
Powershot A430 canon camera battery problem
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Aug 08, 2008 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 Digital Camera Logo
209 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
