Question about Focus Enhancement FireStore FS-4 Pro (ASYF092701) Hard Drive
Firestore FS-4 does not show up when connected
When I hook up my FS-4, windows vista does not recognize it yet the unit says connection sucessful.
I own three FS-4 and one of them has the same problem. Two of them connect no problem. The third one says the connection is successful but windows doesn't recognize it. After playing around a bit it appears that I am not getting a good connection with the 6 pin firewire output on the Firestore. I find that with repeated attempts and carefully holding the cable in various positions, I eventually get it (reminds me of analog TV antennas when you have to be in just the right position to get a channel in clearly). The good news is, once it is recognized, it stays recognized until the need for the next download.
So for my unit, I think I simply have a bad jack. Hope this helps.
Lance
Posted on Jan 23, 2009
Update firmware to firestore fs-100
salve, volevo trasformare il mio firestore fs100 dte da NTSC a PAL. ? possibile tramite firmware?
Sep 14, 2013 | Focus Enhancements FireStore DVCPRO HD...
Navman ezy not connecting to desktop
I had the same problem here in New Zealand. Navman would be recognized using USB.
I tried it with Windows Vista and Windows XP. In the end, I connected to windows 7, it was immediately recognized. I had the option to apply a few upgrades which I did.
After the upgrade, it now also works for windows vista and windows XP
Apr 30, 2012 | GPS
Unit re-powers after being turned off. Only removing the battery gets it to shut down without re-powering.
When it repowers,is it because when you hold the unit,it repowers? Then once it shuts down put the unit down.
Feb 15, 2010 | Focus Enhancement FireStore FS-4Pro HD...
Firewire 4 pin connection is npt reliable with my firestore fs 100. Can I fix this myself?
Hello there!! I think that you mean that the firewire connections is faulty with alot of errors during rec.This is caused by many movements in the cable and so the connector after a while gets loosen. I mean the 4 pins inside it. Therefore you should replace the 4p connector .You need to have experience in replacing connectors like this,not so easy though. Another solution for this kind of problem is to put some kind of glue around it so when it gets solid no more movements will happen again, but this is not the real solution.
Jul 17, 2009 | Panasonic AJ-P2COO8HG for AG-HVX200...
Windows 98 PC won't recognize Lexmark 75 printer
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Oct 05, 2008 | Lexmark X75 All-In-One InkJet Printer
Firestore FS-4
Try a factory reset - it will probably fix the problems you're seeing. These are the instructions I got from Focus Enhancements: FACTORY RESET
a. With the Firestore powered OFF.
b. REMOVE the “battery” and connect the “AC Adaptor”.
c. Press and HOLD down the "ON” and “OFF” buttons for 15' seconds, then release just the “ON” Button.
d. Count to five (5) then release the “OFF” button.
e. The Firestore should be powering back up to the home screen.
(It takes the firestores settings back to the normal setup. This "will not" erase any current footage on the drive) (You may have to re-do current update/upgrade version)
Aug 10, 2008 | Focus Enhancement Firestore FS-4 Hard...
NOt recognized
if your trying to download video usb won't work! must use firewire cable hooked up to dv port on cam and connection on laptop or tower called 1394-cable is either 4 pin or 6 pin-depends on computer- cam is always 4 pin-says dv on camcorder-usb only for still pics-use windows movie maker in xp or vista to edit
Jun 28, 2008 | Canon MV700 Mini DV Digital Camcorder
Wireless network
Do you have the full model number? So I can check what kind of driver you have?
Also whic operating system you use? Windows XP? ... 2000?
Vista?
Jun 23, 2008 | Compaq Presario 700 470024-192 Notebook
Firestore FS-4 no longer recognized as external drive by Macs
bad firewire port try getting a new firewire card throw usb many or pcmia pci card for desktops
Jan 30, 2008 | Video Cameras
Focus Enhancement FireStore FS-4 Pro (ASYF092701) Hard Drive Logo
340 people viewed this question
Top Focus Enhancement Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Focus Enhancement Computer and Internet Expert? Answer questions, earn points and help others
