Question about Cooktops
Ticking sound of gas igniter continues after off.
On our GE gas cooktop the igniter continues to arc (click) even though all knobs are set to off. The condition is not limited to any one burner as the visible arc occurs at any one of the four burners. Removing the burner heads seems to stop the action, however when a head is replaced, the igniter arcing will happen again at that burner. Removing that head and replacing at another burner will cause the arcing to shift to that burner. I am not sure of the model number, but our owners manual lists the following JGP326; JGP930; JGP336
  • lvmarriotts Dec 04, 2008
    When the burners are off, sometimes the igniters on two of the burners start to click and will not stop.
  • stevefleck Apr 21, 2009
    i have the exact same problem and GE wants to send a tech out for 99.95 plus parts and labor to fix
I hasd this problem I searched the iternet and read to unplug the unit which I did and the clicking stopped - this was after I had a technicicn come out and repair it once !!
Posted on Jan 07, 2011
    Novelist:
  • 222 Answers
Try to clean the place wen u remove the control knob,by using a vacium.
Posted on Dec 02, 2008
Middle section ticking sound with sparking as if trying to ignite even though knobs
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
After spraying stainless steel cleaner on the cooktop, with the knobs removed, the igniter won't stop ticking as if it's trying to ignite. All the knobs are securely in the off position. Could this be...
Yes, the moisture is probably the problem...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 21, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
The igniter doesn't work at all. If I turn any knob to the ignite setting, you can hear the gas coming out but there is no ticking sound, and therefore no ignition. Can I fix this myself?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 03, 2010 | GE 36 in. JGP628 Gas Cooktop
We have a belling gas hob. Intially when we turn on the control knob it gave a ticking sound even after it got ignited. then when we were turning on one burner it gave ticking sound in all burners . but...
take out the control knobs. clean the grease and food partilcles if any using hot water and dish washing liquid .if the washer under the knob is stuck, put it properly and put the control knobs back into it carefully
Jan 11, 2010 | Stainless Cooktops
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
Oct 28, 2008 | GE 30 in. JGP336 Gas Cooktop
Ticking sound from GE cooktop igniter
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
May 25, 2008 | GE 36 in. JGP628 Gas Cooktop
Ticking sound does not go off even after knob is turned to high or medium
A lot of questions on this site but very few answers. I have the same problem. After an overflow from a pot, the 2 front burners now won't light one rear one lights but won't stop sparking and the littlest one is fine.
Mar 30, 2008 | GE 30 in. Profile JGP933SEFSS Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Cooktops Logo
784 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
