Question about Mitsubishi WS-65907 65" Rear Projection Television
No Picture The TV was working fine the day before. It was on 20 hours straight. Now when I turn it on the green light comes on and I get perfect sound but no picture, just a completely black screen.
  • 1 more comment
  • klausj Nov 19, 2008
    What do you mean the picture tube is blown? What exactly blows in a Picture Tube? Are you talking about a bad filament? All 3 CRT's at once?
  • klausj Nov 25, 2008
    I have a Mitsubishi WS-65907 TV. The TV was left on for about 20 hours straight, then turned of ovenight. Now the picture will not come on. There is sound for all the channels but no Image or raster of any kind.
    Novelist:
  • 98 Answers
Actually, rather than rush out buying and installing parts that you may or may not need, I would suggest calling one or two local TV repair centers to get an expert opinion and an estimate on what it will cost to get your television fixed. Without having the TV tighr in fron tof me, it's really hard to say exactly what's wrong with it. I could be a power supply, transformer, capacitor, or the picture tube. It could turn out to be none of these things given the possibility that perhaps the circuit board got hot ofter 20 hours and maybe a solder connections on a resistor or something came loose.
Most TV repair centers will diagnose your TV for about $20, and if you decide to have them do the work, they'll apply that $20 into the total cost of your invoice. Like I said though, to prevent coming across a shady repairman, I would definitely call around to at least 2 or 3 repair centers to get more than just one opinion. Hope this proves to be helpful and have a wonderful evening!
James
Posted on Nov 25, 2008
  • 4,806 Answers
Have a look at the lamps inside the tv itself, they are red, green and blue, check to see if the are all working if they are not, check that the lamp board is getting power, and check for a fuse that has blown, if the test shows that there is power then you may have to replace the lamps, they just unscrew like standard light bulbs and are easy to replace
hope this helps
regards
    Genius:
  • 1,550 Answers
I think you need to replace the transformer inside the tv .
It will cost you around $400 to replace it .
Hard reset will work but it is not permanent solution to your problem .
How old is your tv ?
Posted on Nov 19, 2008
  • 73 Answers
The picture tube has blown, with these tv's they tend to blow out a few years after or when the tv has been left on for longer periods in shorter times, i suggest you replace the picture tube but sometimes its cheaper to replace the tv itself. replacing the pture tube will do the tirck.
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
My TH-50PX70A Plasma TV, has lost its picture and only has sound. When you turn it only the green power light flickers on and off rapidly (approx 15-20 times) the TV switches on to a dull black and the...
The most likely issue is that the Power Supply has burnt out, you were able to let it cool at get it to work for a while, but perhaps part of the board has melted enough to cause a short. Repairs will cost approx. $300-500.
Jan 13, 2011 | Panasonic TH-50PX70 50 in. Plasma TV
My 32TV has green light but won't turn on, or takes an hour
You may have failing power supply module, that will be the first place to look, look for caps with leaking/bulging top.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Parts: WWW.SHOPJIMMY.COM
Jun 12, 2010 | Televison & Video
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
