Dropped Kodak C530, still takes good-normal indoor photos with auto flash but outdoor photos with out flash are almost completely white. Can this fixed easily ?
This FE-340 Olympus is a great camera. Lots of features and usually great results
Indoor pictures with flash set on auto WB (white balance) should not be a problem
Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
You will need to adjust the "white balance". Your camera may be able to do this by pointing it at a gray surface, and setting something. I don't have your camera instructions, but it's a normal adjustment for indoors.
That would depend on a lot of factors. Are you doing the outdoor photography in the day or at night? Are you doing the indoor photography in the day or at night? With just existing light or with aritificial light? What do you want the photos to say to the viewer?
I'm going to go out on a limb and assume you want to take pictures for real estate sales purposes. If not, please reply to this post and say what you want the photos for.
Outdoors, I'd just put the camera into the Program (P) exposure mode. Since the house and shrubbery aren't going to be moving very fast, the autofocus setting doesn't matter much (just make sure it is set to one of the autofocus modes, not manual). Leave the white balance on auto.
Indoor, if there's enough daylight coming in through the windows, go with Program exposure, any autofocus, and auto white balance. If you have to use floodlights, set the white balance to match the floods. The camera's built-in flash won't evely illuminate a room (nearer stuff will be much brighter than the farther stuff), so don't use it. You can use an external flash with a diffuser or bounced off the ceiling or a wall.
Hi
Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor.
Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge.
Thanks and best regard!
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
