Question about Craftsman Garden
I think the ignition switch is bad or the starter
The battery is fine. I turn the start key and all I get is a click. I asked my husband to fix it before he died but, he got to sick to do it and never told exactly what the problem was. Can you help me? The tractor is Craftsman II 18 hp 44" deck model: 917.2559101. They say it from 1987 or before. Sandy
Right below the starter solenoid is the clutch pedal position sensor. Try wiggling the connector to see if it starts. If it does remove the connector, clean contacts and apply die electric grease.
Posted on Feb 28, 2009
  • 3 Answers
You say the battery is fine . Make sure the battery post are clean. Tighten all the nuts & bolts .Sometimes it will click if they are loose. Check nuts & bolts on the starter also . Also look at the wires that lead up to the switch .Make sure all of the wires are clean and tight .The switch key may have to be replaced or the starter repaired .Good luck !
Posted on Nov 19, 2008
Turn key wont crank
Possible issues: too many to list
Do you hear a clicking sound when you turn the key to "START"? If so, I'd say your battery is dead.
Do any of your gauge lights, head lights, radio, etc. work just fine? If so, I'd guess you have a bad ignition, bad coil, or bad starter.
Likely issues:
Dead battery
Bad coil
Bad ignition switch
Bad starter
Feb 08, 2014 | Nissan 350Z Cars & Trucks
1999 Dodge Ram Conversion Van won't start. After many attempts the battery finally died but before it did it was making a clicking noise when we tried to start it. My husband saw a spark under the...
I hope that you have disconnected the battery fire could happen relay click's but will stick at drain could be the fuel pump you hear with the continuse click you might have a shorted starter.I think thats the first place to start.A bad ignition switch will cause this to happen sometimes?
Jan 11, 2018 | 1999 Dodge Ram
I have a 2000 VW Golf and am having problems starting it. I had the starter checked it was fine I was told that the ignition was bad so I replaced it, the car still will not start. Now they are telling me...
will not blame anyone 1st have you checked the black fuse box under the hood?if not,then look for main relay box(black) remove the cover,then look under the cover lid for relay locations. find starter relay.have some one Put their finger on top of the black square starter relay,then you turn your key switch to "on" does the relay that the fingers on click? if so,its'good. you also have what garages call a fuseable link.it's a hard black peice of rubber thats located in between the starter and the battery. but 1ST LETS COVER THE MAIN ISSUES WITH NO START! IS BATTERY FULLY CHARGED?A MUST! WHEN YOUR CAR IS ALL THE WAY IN PARK AND YOU TURN THE KEY TO START,NOTHING AS MUCH AS A CLICK? DID YOU HEAR A CLICK? GO TOWARDS A BAD STARTER CONNECTION,OR BAD STARTER.ARE STARTER BOLTS TIGHT? IS BATTERY TERMINALS TIGHT,THINK I ASKED THIS EARLIER BUT JUST 2 B SURE.
Apr 08, 2011 | Volkswagen Golf Cars & Trucks
We replaced the battery and alternator in our 2003 pontiac grand am about a week ago. Yesturday the battery light came on....We also are having problems when starting the car. When we turn the key...
Hey DaisyMae
I do not believe its the ignition switch.
Sounds more like the battery is not making really good connections or its a bad battery. Take the battery and have the CCA (Cold Cranking Amps) checked.(the true measure of the quality of a battery).. Home Page Reilly Auto Parts These people can check it. If the battery checks good, make sure the battery connections are clean and TIGHT.. NOW - ..IF the same clicking still happens, time to check the starter solenoid and starter, -(make sure their connections are tight) ... the solenoid is located on the starter. IF ya'll are mechanically inclined you can remove the starter/solenoid and it's back to O'Reilly's for a check... Your problem is 99.99% one of these items. (disconnect the battery when removing the starter)..
Please rate as helpful ..if this helps..thanks and good luck.
Jul 09, 2017 | 2003 Pontiac Grand Am
I drove to school and it ran fine. When I left class and tried to start it, the key turned freely with no resistance at all and nothing happened, it did not try to start at all. the battery read good and...
suggest a bad starter or a bad connection to starter, sometimes you can tap on the starter with a hammer and get it to start one last time.make sure cars in park with emergancy brake on!! have some hold key over in start position and you tap on starter with hammer to see if it even clicks, sometimes they will either click or even start, depaending on how bad the colenoind is on the starter. be very careful when tapping as not to cross out and hit the positive cable on the starter. hope this helps!!
Nov 10, 2010 | 1993 Jeep Grand Cherokee
IS THERE A FUSE FOR THE ECU ON A 92 EAGLE TALON
I don't think so. I got a 95 and I've done all kinds of electrical checking for various things and to my knowledge there isn't. There's fuses for the ignition and engine along with other electrical items but no specific computer fuse that would turn off a computer. I assume the car won't start?
If your car is simply not starting it could be something as simple as the neutral safety switch if you only hear a click turning the key. Disconnect under left side dash. White and has a green and black wire coming from button behind clutch pedal.
If car cranks but just wont start then could be numerous things. Check the 30 and 40 amp fuses under hood. Make sure battery terminals are connected tight and clean with brush tool if needed. If battery is fine and charged, I assume you have checked, then I'd focus on the ignition system.
ignition switch (in steering column)
neutral safety switch (disconnect above pedal)
starter relay (under radio)
starter solenoid
starter
If cranks then neutral, ignition and relay switches are fine
If clicks then ignition and relay fine but neutral switch or solenoid may be bad
Jan 26, 2010 | 1992 Eagle Talon
Intermitent start
Bad/malfunctioning relay. Let me know if you want to work on this.
Jun 01, 2009 | 1995 Mercury Villager
1999 Honda Accord, 5 speed
It could either be a BAD starter or a BAD ignition they both would have the same symptoms of a "CLICK" alone. I would most likely lean toward the ignition because the key is difficult to turn but its not all ways true that key is tight because the ignition is bad, although possible. It could just mean a bad ignition cylinder(just the key part why its tight) I want you to do a test for me. With clutch engaged turn key to start position and listen for click on starter in the hood, when trying to start. If you hear starter click then the ignition switch is good. (Before you do this make sure that battery is FULLY CHARGED).STARTER IS AT FAULT. IF no clicking is heard coming from starter check starter fuse and if its good YOU have a BAD ignition switch. Contact if you need more hep and Thanks for using FIX YA
Jan 14, 2009 | 1999 Honda Accord
2002 GMC Envoy
If your 2002 gmc envoy or sierra will not even turn over with a kown good battery try starting it in nuetral then go back to park and try starting again. There is a park nuetral safety switch that can malfunction. Turn the key on then shift into nuetral, then turn fully to start.
May 19, 2008 | 2002 GMC Envoy
Garden Logo
222 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
