Question about Dishwashers
Middle spray arm not spraying
After 3 months and 8 visits from Sears to repair our 1.5 yr old dishwasher, they finally called it a lemon. The problem was that the spray arm under the top rack would not spin. Many parts replaced, but still did not work. So, yesterday, they came and installed our BRAND NEW top of the line Kenmore dishwasher and guess what? top rack dishes not clean and spray arm under the top rack NOT SPINNING! Our water was evaluated, no problem, our water pressure and fill speed, great. Please let me know if you've ever seen this before and any possible solutions??? This is driving me crazy. I'm wondering if it could be a "level" thing? Could it somehow not be level and that's affecting this spray arm and only this one? Thanks for any advice.
    President:
  • 1,462 Answers
Unlikely that 2 dishwashers would have the same fault but is of course possible
could it be to do with how you are loading? quite common is for a knife or similiar to stick down thro the rack and jam the arm
Posted on Nov 20, 2008
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
LG model LDS4821ST.... Top and Upper spray arms arn't rotating.
I have an LG LDF8922ST model with the same exact problem (16 months old as well). I think you are right about the vario spray system. Seems like the repair guys that come out are clueless and get very little assistance from LG customer assistance. I will never buy another LG product again.
May 28, 2010 | LG 24" XL Tall Tub Built-In Dishwasher -...
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Leaking Kenmore Elite at the right front of dishwasher
Sorry to hear of your plight. My advice is to ask for a new machine under the lemon law since they cannot get it fixed. You can also try calling Whirlpool who is the manufacturer but they are likely to tell you to work with Sears. They were out under warranty and it has not remained fixed so the warranty should carry through since you called for service while still in warranty. I feel for the tech because it is frustrating to have a problem that you cannot find a cure for be the tech should also have escalated it to the tech support line for resolution. (I was a Sears tech for 21 years)
Sep 14, 2009 | Kenmore 15129 Built-in Dishwasher
I have a Kenmore dishwasher that will not pump water through the spray arms. It fills ok and drains fine but wont go into the wash cycle? Any idea of possible problems
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
Apr 18, 2009 | Kenmore 15762 Dishwasher
Lower spray arm is not rotating
call sears help line thewy have mech that can help
Mar 14, 2009 | Kenmore 15899 Built-in Dishwasher
Rotory spray arm
The most likely cause is that some of the holes in the spray arm are blocked. Candy wrappers, tooth picks, seeds, nut shells or other food objects can get into the spray arm and block up the holes. If you can't get them cleaned out you may have to replace the spray arm.
Nov 08, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Kenmore Dishwasher Not Cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k;kjguit
Jul 31, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
358 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
