Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
My vaporizer is making a spitting sound -
I filled up my vaporizer, added 4 pinches of salt and 1 tablespoon of Vicks Vapo Steam liquid medication. Slowly dropped the blue part of the unit into the water. I turned the unit on and now it is making a constant spitting/static sound. Any ideas why?
Neda
  • Anonymous Mar 09, 2009
    Mine does this, too and cleaning does not help.
  • jessdrake Oct 14, 2009
    i just bought one for my daughter who has bad allergies. it produces so much black gunk every night im afraid to use it. i clean it and refill it every night but ****, is it worth all this trouble. i even bought the purifier for it. doesnt help. i feel like im just blowing mold into her air...
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Posted on Dec 07, 2008
  • 3 Answers
The gunk is in your water - you have hard water. As hoosierbuy said, don't add salt -- that is only needed if your water is too soft.
Posted on Jan 14, 2010
    New Friend:
    Problem Solver:
You need to clean it, the minerals in your water can cause a build up. Empty all water and any debris remaining in the bottom of the vessel. Fill with distilled vinegar, allow to set for 10 minutes and then run the vaporizer for 5 minutes. Flush water through you unit to remove any loosened buildup, and fill with distilled water instead of tap water. If you still have issues, take it back to the store for a refund.
Posted on Dec 02, 2014
  • Anonymous Jan 07, 2018
    If you use distilled water you may have to add a very tiny amount of salt to make the water conduct electricity so it can boil. Don't add any more salt after that as it will remain in the tank after the water boils off. Salt is only needed if there aren't enough minerals in the water for the electricity to heat it up. If it doesn't boil, only then do you need the salt.
Test
Posted on Jan 23, 2014
  • ron_coxx Jan 23, 2014
    Take the thing apart. Find a small flathead that fits the star head screw if you don't have a star driver. Chip / scrape the mineral build up off the elements, gently. Reassemble. Viola..
    Not sure why I can't add solution but tired of losing my attempted posts. There are only two screws. Pull apart once you get the screws out. Clean out all deposits. No waiting.
I think you don't have to worry about the dirt. According to the manual it is normal and it doean't affect the purity of the steam or the medicine.
Posted on Feb 17, 2010
    It's mineral deposits not dirt. If its dirt you have bigger problems.
I have hard water, plugged it in, no steam. Added salt, no steam. What to do?
I have hard water as well and I wasn't getting steam. I put in a good tablespoon of salt and the steam started immediately. Try more than a pinch (if that's all you put in originally)
Oct 16, 2012 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I am sorry but i didn't understand if i need to mix de medicine with water or put in medicine cup. I lost the instructions....thanks
the vapour oil medicine is put in the little reservoir right at the front top on the blue unit that sits on the plastic base... about a tablespoon. It will still be there after use, but it's only oil residue, after the medicine has evaporated with steam. clean it out with paper towel and refill for each use when needed. Only salt is added to the water, not the oil...
Mar 09, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer is spitting water
You added too much salt. Clean it out, start over with less salt.
Feb 08, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Spitting noises and gushing water
Another alternative to vinegar is to use lemon juice. About 1 cup to a tank of water should do the trick. It smells much better than vinegar and also has the acid content to clean the vaporizer.
Jan 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
8,889 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
