Lost internet connection to my 2nd wireless p.c
Iam running 3 pc's in my home at present. no1 pc is thru optus cable & other 2 on wireless setup thru linksys 2.4ghz broadband router,pc 2 working on wireless upstairs ok.i moved pc 3 from downstairs to another room upstairs and have lost our internet connection. now we are picking up a weak internet singal from our neighbours pc but signal strength is low & still no internet connection.do you have any suggestions to fix my problem.
  • 120 Answers
Suggestion: Move your router. Your PC 3 appears to be in a 'dead zone' so to speak.
Posted on Nov 21, 2008
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
I can't connect to the internet with my wireless LAN
HI
may be your wireless has password protected
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 26, 2010 | HP Compaq Evo n400c Notebook
WAN connection problems with Linksys WRT160N
1.) Have you setup the router for use on cable modem?
2.) Run Your Setup utility that came on the CD for the router. And select Dynamic under the WAN settings unless you have a static IP address.
3.) If you do not have the CD to access the setup use IE Browser type 192.168.1.1. Select WAN settings and then Dynamic from the list.
4.) Make sure your computers are using the router and not the cable modem. Reboot your PC's and verify they work if they don't open the internet connections and view the gateway is 192.168.1.1?
Here is a link to the manual
Nov 26, 2009 | Linksys WRT160N Wireless Router
Connection issue
Hi! I believe your having some issue with your router and I will be more than glad to assist you in this concern..Time warner cable is your isp and if the computer is connected directly to the modem, you have a perfect internet connection but if you are going to connect the cable from your modem to the router and you connect your computer to port 1 to 4 of your router it will not give u an internet connection. This is what we are going to do.
1. connect your computer that can get an internet connecttion thru time warner cable to the router on port1.
2. pull up a browser and type in the default gateway of the router, to check the default gateway of the router, right click the network icon on the lower right of the task bar and click status and it will show the ip address, subnet and default gateway, ex the default gateway is 192.168.1.1, u are going to type in the default gateway ip address to the url of the browser.
3. It will ask u for the username and password, by default the username is admin and the password is 1234 or just leave it blank.
4. It will pop up the setup page of the router and you have to look for the setting for doing a mac clone, you need to clone the mac address of your pc that can connect to the internet thru time warner cable modem.
5. once its done, save the settings and on the internet connection settings, manualy configured it to auto-dhcp. save the settings.
6. once its done..unplg the power of the computer, router and modem.
7. cable connection should be, cable from the modem goes to the WAN port of the router and connect cable on port 1 of the router to your computer on the lan port.
8. Plug in 1st the power of the cable modem, once all lights are lit then plug in the power of the router, once all lights are solid on the router, like the power, WAN, u will notice that there is no light on the port1, computer is still off, once the computer is on port1 will lit, then power on the computer..once computer is completely boot up, pull up a browser and it should gives u an internet connection.
9. Once you have an internet connection, u can access again the setup page of the router to setup the wireless connection settings.
10. If you are going to connect another to the existing router that is conneted to the time warner cable. that is possible, but before u connect the 2nd router to the 1st router..
a. connect the 2nd router to a computer to set it up..you have to access the setup page of the 2nd router.
b. once you access the setup page, there is a menu for the lan settings that is for the router side. u need to change the 3 octet of the ip address of the 2nd router. ex your 1st router ip address is 192.168.1.1 and the 2nd router ip address is 192.168.1.1 to change the 3 octet of the 2nd route, the 2nd router ip address should be 192.168.2.1. then save the settings..
c. the router will reboot and need to access the setup page of the router by using the 192.168.2.1 and u can set the wireless connection settings.. once its done..
d. cable connection should be---cable from the time warner cable goes to the WAN port of the 1st router, connect a cable to port 4 of the 1st router going to the WAN port of the 2nd router.. this process is called cascading two routers on a network.. this should work.. good luck
Aug 16, 2009 | ViewSonic (DHWMG120) Router
Can't connect with 2nd computer...
1st.  What brand and model # of your router? 2. The router cd should be run only on the computer u have connected to the router with a network cable. Your vista laptop. Is it connected with to the router with a cable? 3. If so, it will be the one used to configure your router for wireless setup. When you ran the setup it should have gone thru Wireless Setup. It will ask you for an SSID. That is a name you will give your wirless network. It can be anything you want. just remember it.  It will also ask you to setup security for your wireless network. follow the instructions to setup a password. write it down. This is an important step so anyone cannot just logon to your wireless signal an start using ur internet connection or gain access to your computers. 4. when u setup your dongle on your kids computer it will search for wireless signals in the area. you will look for the one u setup in the previeous step. you will select it and it should ask you for the passkey you setup. once connected you will have access to the internet.
Think of your router as a private radio station and the wireless usb dongle is the radio. The only way your computers can tune to it is using the dongle and if you know the name of the station (your SSID) and the passkey.
Mar 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Jan 20, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
260 people viewed this question
Alun Cox
David Payne
David Payne
