Question about Mitsubishi VS-50605 50" Rear Projection Television
Dead Mitsubishi VS-5006R.
Hello:) When I press the power button, all I get is a soft "click" like sound. This TV was given to me and he said it just stopped working. I had a electronics repair shop back in the 90's. I know how to replace parts and work on TVs safely without getting zapped. I am just terrible at troubleshooting TVs. Thank You.
  • 4 more comments
  • mattie_2 Sep 05, 2008
    My mitsubishi 8728811 showed a message stating to change the input or in 2 minutes it will shut down. Apparently I wasn't fast enough. Now it is dead. Won't even turn on manually. I'm a single woman and I need some
    help here....I don't know what to do.??
  • cockboy Oct 01, 2008
    i have a mitz vs50605 great tv never a problem till today went to turn it on dead like a door nail no green light just press power and nothingggggggggg!!!!help!!!!!!!!!
  • ignatz49 Oct 08, 2008
    my vs-50605 comes on for a second then dead. the error code is a 22. what should i replace and where do i find it?
  • bellyboop Oct 10, 2008
    My TV also makes no response when I push the power button--completely dead. I know I can't fix it myself, so how should I go about finding someone who can repair it, and can you give me an idea of approximately how much it should cost?
    Thanks.
  • cloverleaf2 Nov 17, 2008
    Yes I have the same problem.. TV makes a "click" noise but nothing happends (dead) but my TV is a Mitsubishi VS-4504R model.
    Would it be the same "solutions" for my TV as for the origal poster with the
    Mitsubishi VS-5006R?
    Thank You for any help.
    Jennifer
  • tellest Dec 03, 2008
    I just get a soft click too. I was watching tv and all of a sudden the tv died, slowly. And now all i get is a soft click when I plug it in. I press the power button and nothing happens :(
    President:
  • 3,130 Answers
The most common problem with this set in the start up circuit of the power supply. There is a resistor, a 270k, R903, and even if it checks or looks good replace C920. Also there are small resistors off the flyback transformer that will open up because of bad capacitors feeding those circuits. Also any capacitor that has a swollen top or body, replace. Double check and make sure the B+ fuse is not blown. If it is, before you replace it, check to see if the horizontal output transistor is shorted. If it is, replace the transistor, BUT intall a 100 watt light bulb across the blown fuse. If , when you turn on the TV set, the light bulb glows bright, one of the deflection yolks is probably shorted. Unplug the set, and pull out one of the yolk plugs. tun back on the set. If the light now glows dim you have the bad yolk. If it does not and is atill bright, unplug the set, replug in the yolk, and take another yolk plug out. Do in this order and replug back in the tested yolk and make sure you unplug the set each time you do this or you will cause more problems. goos Luck. Please do not forget to rate this thread.
Posted on Dec 11, 2006
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Green power light on but no sound or picture.
When I press the power button it just clicks.... what. ... vs-60603 I will only stay on for a few seconds and then shuts off. ...
Mar 30, 2009 | Mitsubishi VS-45502 45" TV
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-6041 60 in. doesn't power up
Hello Tremulant
This denotes a possible problem with the Low or high voltage power supplies. The clicking you here might be the shutdown circuit acting because of excessive draw of current. The problem will most likely be associated with the HV power supply, but you will have to have a qualified TV technician check your TV to make sure.
I hope this helps,
Thank you,
Shuttle83
May 31, 2008 | Mitsubishi VS-6041 60" Rear Projection...
My big screen tv
this is usually a problem with one of the voltage regulators, or the horizontal output transistors.
Apr 23, 2008 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-5052 tv
as you are not electronic person so call skilled person. problem is simple. 1 there might be in power supply. 2 if power supply is ok horizontal section might be defective
Sep 16, 2007 | Mitsubishi WS-65615 65" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
336 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
