Question about Texas Instruments TI-86 Calculator
I need help with square root functions
The problem is ^4 square root of 21.2846
  • Texas Instru... Master
  • 7,993 Answers
The square root has a dedicated key sequence [2nd][V square root symbol]
Square root of 21.2846 is entered [2nd][V square root] 21.2846 [ENTER] .
The result is`4.614.
I suspect you want to calculate the 4th root of 21.2846. If it is the case you enter that as
21.2846 [^](1/4) =2.148
Square root can be also entered as [^](1/2)
Cube root is entered as [^] (1/3)
nth root is entered as [^](1/n)
Hope it helps.
Posted on Sep 23, 2009
Testimonial: "thanks sorry for the REALLY late reply!"
SOURCE: Need Help Solving Exponential Functions ASAP!!!!
You can calculate =4^1.2 in Excel and get 5.278031643
And also in Excel you can determine what the square root of 2 is (2.506628274631) and then in Excel = 5 ^ 2.506628274631 = 56.5012395907155.
I know this is late but maybe it will help later. Assuming I am doing it right. Thanks!
Posted on Apr 15, 2009
  • 13 Answers
SOURCE: I need to use the square root sign but I need to
If you would like to a root other than a square root, first enter the root value (3, 4, 5, etc.) then press MATH. Then Press 5 and enter the value you want to take that root of. Press ENTER.
Posted on Jun 16, 2009
SOURCE: Square root on FX-83ES
make sure you havnt droppend your calculator as this can damage the chip, if so , re solder broken parts and it sshould work, this happened on mine and after i soldered it it is fixed.
online companies can fix it if you send it away
Posted on Sep 10, 2008
  • 7993 Answers
SOURCE: TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Posted on Sep 07, 2009
ur fortune
  • 85 Answers
SOURCE: I want to find the square root of a number and the
if it is a perfct square root then u will get a integer part.....if its not a perfect square root than obviously u will get decimal part........ u just check ur calculater in which mode it is......exit the radian and do it
Posted on Oct 15, 2009
How to calculate the square root
The square root is the second function of the "3" key. To calculate the square root of 3, press 3 2ndF 3 =
May 25, 2013 | Sharp EL-738 Scientific Calculator
4 squre root 81
Take the fourth root. The square root, denoted by a 2 on top of the "root thing" or more commonly without a number at all, is the second root.
Usually the easiest way to calculate the fourth root is to calculate the square root of the square root. So in this case the fourth root of 81 is the square root of the square root of 81. The square root of 81 is 9, the square root of 9 is 3.
Apr 18, 2013 | Office Equipment & Supplies
How to use square root for non square numbers for casio graphing calculator
You can use the square-root function for any number, whether it's a perfect square or not. For example, to calculate the square root of 2, press SHIFT [square-root] 2 EXE .
[square-root] is on the x^2 key, just to the right of the ALPHA key.
Jan 17, 2013 | Casio FX-9860GII Graphing Calculator With...
What Has The Same Value As Square Root Of 7 Multiply By Square Root Of 15
(Square root(7))*(Square root (15))=(Square root (7*15)=Square root(105)
Mar 29, 2012 | MathRescue Word Problems Of Algebra Lite
Have TI30xIIS calculator. How do I find square root of a number. For example, the square root of 9. Where is the square root? I know 3 is the square root of 9, but how do I do this on calculator. ...
To calculate the square root of 9, press
2nd [square-root] 9 ) =
The square-root is the shifted function of the x-squared key, just to the left of the 7 key. The close-parenthesis is needed to balance the open-parenthesis automatically inserted by the square-root function.
Feb 16, 2011 | Texas Instruments TI-30 XIIS Calculator
How do a take a division problem and square root it on a TI-84 Plus Silver Edition for example 87.34/5 then square root the answer. I can do the math, but how do I take the dvision answer and square...
Two ways:
2ND [square-root] ( 8 7 . 3 4 / 5 ) ENTER
8 7 . 3 4 / 5 ENTER then 2ND [square-root] 2ND ANS ENTER
The first sequence takes the square root of 87.34/5, the second sequence calculates 87.34/5 then takes the square root of the result.
Dec 15, 2010 | Texas Instruments TI-84 Plus Calculator
Were is the square root button on the TI-30XIIS and how do I solve, what is the square root of 62
Square root is the 2nd function of the square key, to the left of the 7 key. To compute the square root of 62, press 2nd [square-root] 6 2 ) =
Nov 15, 2010 | Texas Instruments TI-30 XIIS Calculator
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-86 Calculator Logo
1,581 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
