Question about Frigidaire PLMV169DC Microwave Oven
Panel control I need replace the pamel control face, the plastic is scrathed, how do i order this part ? the microwave model is "PLMVZ169GL" . tHANKS
  • Frigidaire Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Nov 24, 2008
Replacing keypad smh9187st
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
Jan 06, 2013 | Samsung Microwave Ovens
Samsung Microwave SMH9187 error message (?) 5E
Aug 15, 2012 | Samsung SMH9187 Microwave Oven
The brightness of the display panel on the GE XL1800 is so dull I cannot even read it. How do you increase brightness?
There are two main causes for this:
- Dust & other particle buildup on the front of the display gass and the rear of the display window. This can be cleaned.
- Your vacuum display tube is wearing out and the control circuti board must be replaced.
Cleaning the display is easy, but you need to be careful so you don't break the glass.
First you would unplug the microwave or turn off its breaker.
Then see the video here that shows you how to remove your control panel assembly in less than 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the plastic frame.
Then carefully (since the display is made of glass) remove your circuit board.
Using a soft cloth (since paper towels can scratch) lightly dampened with non-ammonia cleaner (since ammonia can damage some polycarbonate plastics), gently wipe off the front of the glass.
Then gently wipe off the back side of the plastic display window in the plastic control panel frame.
Reassemble, reinstall, and power it up, and it should be brighter, sometimes a whole lot brighter!
If that does not brighten it up enough, then you will need to replace the entire circuit board, since the display tube on this brand is not available as a separate part.
You can use the disassembly instructions above, and the board can be ordered by entering the full model number from the tag in or on your unit here.
For those with other brands, or whose model does not show up there, see this page for tips to finding helpful exploded views and ordering appliance parts and accessories.
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Touch Control panel of my daewoo KOT-151S microwave needs to be replaced. I have to push control pad several times to get it to operate. Sometimes it will go on after just a few pushes, other times it...
We regularly replace these.
You can send your KOT-151S control panel assembly to us to install a new membrane keypad. The cost would be $64.95.
Or you can order an entire control panel assembly (plastic frame, stainless trim piece, keypad, and control circuit board) for $88.85, which includes return shipping.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 31, 2009 | Daewoo Microwave Ovens
GE microwave Model JVM1540
If you mean the control panel, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you mean the door, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 16, 2009 | GE JVM1540DM Microwave Oven
Samsung microwave auto starting
Please provide the model number of the microwave, and we'll be able to supply the part info. (Some Samsung models with this problem were part of a huge recall).
Sep 04, 2008 | Microwave Ovens
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Apr 30, 2008 | Whirlpool GH7145XF Microwave Oven
Micriowave key panel
The part number for the Control Panel assmbly is WB07X10789, you can order it from numerous places but www.repairclinc.com has it listed as a special order for 110.00. To replace it first shut for the POWER. there are usually 2 screws in the face of the grill above the door, sometimes in the top of the unit. Remove these then the grill will pull off, just above the control panel there is one screw take that out then lift up on the control and pull out on the top, control panel should come out. Be sure you keep track of the wires attached to the control and where to put them back....
Then you will need to separate the control board from the control panel . After that reverse to reassmble
Feb 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Microwave
Sounds like the mounting tabs have broken on the plastic control panel frame. You'll probably have to order both the control panel frame and the membrane keypad since they are attached. You can't peel your keypad off the frame and put it on the new frame. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Search for model number as MT9100SFB0 Another option if you prefer not to replace the control panel frame is to glue it in place, probably from the inside, but you need to be sure the mating surfaces are squeaky clean and dry.
Sep 08, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
55 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
