Question about Motorola Talkabout T5100 (14 Channels) 2-Way Radio
Whenever after I finish talking and release the talk button my walkie talkie always makes an annoying beeping sound. is there a way to stop the beeping sound? Please help!! -Thanks.
  • Anonymous Mar 20, 2014
    both handsets keep beeping twice when not being used
  • Anonymous Mar 28, 2014
    Whenever I push the button to talk, it scans through all the numbers and it will not work. I have a purple motorola and the other one works fine but mine does not. Please assist me because I would like to use these for work.
  • 123 Answers
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
Posted on Dec 12, 2006
Here's a solution finally!! Turn on the radio and press the + button, then while holding it down turn off the radio and then turn it back on after a second, then release the + button. A little icon that looks similar to o))) will no longer be there, which means that the roger feature has been disabled. To re-enable it, turn off the radio, THEN press +, then turn the radio on. Hopefully this helps. It works for other motorola models too, I got this from the manual for the T5500.
Posted on Aug 21, 2007
You are correct except you don't have to hold down the "+" button when you turn it off. Only when you turn it on.
What I'd like to know is....when I first turn it on I see a bunch of icons momentarily which I am assuming are different functions this radio has control over. How do I access them if they're there at all?
Any control secrets good!!! : )
Posted on May 16, 2010
Im a walking radio =)
rotfl
Posted on Nov 10, 2008
SOURCE:
I have a 1998 Motorola Talk about my wife has a work Motorola walkie talkie RMV2080 CAn we communicate with each other if so how ?
No. Your Talkabout radio operates on UHF and your wife's walkie talkie is a VHF radio operating on exclusive business frequencies.
Dec 16, 2017 | Motorola Radio Communications
How to use the motorola talkabout 101
The Talkabout 101 is a very basic walkietalkie radio. With good batteries installed in the battery compartment, you should be able to turn the radio on, and simply press the front-center push-to-talk (PTT) button and speak. Release the button after speaking so the other person can do the same to talk back to you.
If you are having trouble opening the battery compartment, pull down on the black u-shaped sides and the back portion of the radio will slide down with the u-shaped sides to reveal the compartment. (This would be one of the most common questions asked on this style radio.)
Best regards.
Aug 30, 2014 | Motorola Pair Talkabout 101 2 Way Frs...
I have a Motorola Talkabout from 1998 that has a talk button, a monitor button, and a power button. Whenever I press the talk button it just says the channel....but when I talk through my other walkie...
It seems a small hardware-problem, like a button is sticking, making a continues connection. If you are comfortable in hardware-modifications, try to open the casing of the malfunctioning walkie talkie. Do this carefully, not to damage it further.
When opened, check the 3 buttons to see any damage, or undesired connections (caused by extensive use or plain dirt).
Oct 14, 2013 | Radio Communications
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
Want to know how to make old nextell / boost Mobil phone walkey talkey or chirrup work for free
Yes it is free, You should have a walkie-talkie ID number. Friends of your walkie talkie also have ID numbers install number to Your contacts scroll down on contact to (Options)D C. From there follow directions try to make a walkie talkie contact by pressing the side (PTT) or push to talk button , It a cinch. This may only work 4 sprint
Jan 22, 2013 | Cell Phones
One of my walky talkys(motorola T4500) makes an extra beeping noise whenever i turn it on. This noise also shortens up what people are saying before they finish talking. How do I fix that?
What you might be experiencing is the Talk Confirmation Tone aka Roger Beep. I have looked through the T4500 manual and do not see any instructions for turning it off, just that it is listed as a feature. However, something you might try is holding in the + (plus) button while turning on the radio and see if it disables the feature. This method is used on many of the other TalkAbout models.
If it is not the Roger Beep, it could be a low battery beep. But from your explanation it sounds more like a Roger Beep.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Best regards.
Aug 25, 2011 | Motorola Talkabout T4500 (7 Channels)...
I have binatone 100 walkie talkies. they have power to them but we cannot talk into them, they just keep bleeping when we try and talk. any suggestions?
  • Have you checked your batteries? This radio will not transmit with to low of batteries but it will beep every 15 seconds or so. This radio utilizes AAA batteries.
  • The other thing this could be is your pressing "Call" rather than "Talk." That's called "call paging tone." So make sure you press the "Talk" button when you want to transmit your voice because if you press "Call" you will only send a 2 second beep.
Regards, Tony
May 02, 2011 | Radio Communications
My biggest issue is the "roger" beep. Want to use it for a hunt, but the beep is constant after hitting the PTT button. I have read that on some models, hold the + or volume button while...
Here is a link to the SX700 manual (very close match to the SX800, which we could not find a user guide for) http://www.giantintl.com/ContentManage/manuals/Moto/SX700.pdf
Look on page 2. Check both the Keypad Tones and the Talk Confirmation Tone (Roger Beep) instructions, on the lower left. This should help you.
Best regards.
Dec 28, 2010 | Motorola Walkie Talkie 2-Way Radio
Lost my owners manuel. when releasing the talk button my radios beep. how do i turn this off?
To
disable the ”Roger” Beep feature, turn your radio off and then back on while pressing and holding Scroll +
button.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
Nov 14, 2009 | Motorola Talkabout T5100 (14 Channels)...
Motorola Talkabout T5100 (14 Channels) 2-Way Radio Logo
802 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
