Question about Freezers
Freezer stopped freezing
I have a G E side by side unit. When I returned home the things in my freezer were defrosted, the ice was melted, and the fridge was not as cold as it usually is. I opened the back and checked for frost or ice and made sure that the fan is working. Is there anything else you can recomend
  • 370 Answers
If you checked the fan and for ice on the back wall (for defrost problem) Then you most likely are low on freon or you have a bad compressor. Check to see if the compressor is running (IF scorching hot its bad too) . Next check to see if the coils under the unit are hot. They should be so hot you cant hold onto them. Just touch for a second. If they are just warm, then you are low in freon.
Posted on Nov 19, 2008
Why do I have ice in the bottom of a whirlpool EV205nxtn upright freezer?
My name s Peter. I am a retired field service technician.
1.) First, lets check your defrost timer. You will need a small flat head screw driver. Pull your freezer out to where you can get behind it. Do not unplug your freezer yet. There is a small white box almost 2" square. On this box is a small shaft with a slot in it. Turn this dial with your screw driver slowly until your unit shuts down (Compressor not running). What you have just done is force your unit into the defrost mode.
If the unit does not shut down you have a bad defrost timer. We are not done with the defrost timer yet.
Take a break, grab a cup of coffee, allow the unit 30 minutes to defrost.
Upon returning if the freezer has defrosted you have a bad defrost timer. Unplug the freezer and replace. Easy job.
2.) Ok, not the timer. Lets check the freezer drain. At times the freezer drain freezes up. When the unit goes into defrost the condensate can not go down the drain and you build up a wall of ice behind the bottom back wall.
Unplug the freezer. Pop the setting control knob off on the lower back panel. You may need a screw driver to wedge it off. Pull the seal strips out on the 2 sides. Unscrew all of the fasteners on the back panel cover. You can not remove the cover yet. You must disconnect the temperature control. There are different mountings. Perhaps 2 screws holding the control to the back cover or a connector where you need a small screw driver to wedge them apart.
Ok, you observe a wall of ice and have a frozen drain. Do not let the freezer defrost itself, you will have a flood. Using a hair dryer and a plastic spatula melt the ice and remove it in chunks. This is a long consuming task, take you time. Be careful not to touch any of the unit components. Let the hair dryer do the work on the evaporator coil etc. Clear the drain with hot water soak up as much as you can. We do not want this to happen again - lets make a heat sink. Taking a piece of 12-14 gauge wire about 3' long, strip about 2" off one end. You should wear gloves. The fins on the evaporator coil are razor sharp. Wrap the striped end of the wire around the defrost heater (Long black bar beneath the evaporator coil). Secure it tightly. Extend the other end of the wire to your drain hole. You want to cut the wire where you strip 2" of exposed bare wire into the drain hole. So, when your defrost heater is on any ice in the drain hole will be melted. Reassemble the back panel. Plug the unit in.
I can not finish. I am limited to size of response
Oct 19, 2014 | Freezers
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Samsung model RS261MD
You have a defrost issue. This link will aid you in diagnosing and parts.
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
Nov 23, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Drain freezes and bottom ices up ii have thawed it cleaned the hose and it does the same thing each time
My be that the unit is not defrosting. There is a timer that turns off the freezer and turns on a heating element to melt the ice in the cooling fins. If this does not happen the fins fill with ice and ice begins to form as the water drips down under the ice. the bottom will freeze and the top will begin to warm.
Sep 19, 2010 | Maytag Freezer MQU2057
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
Panel is hot and freezer does not work!
Check the condenser fan underneath the unit accessable form the back behind the cardboard cover. It should be running when the compressor runs. OR Check the evaporator behind the rear cover inside the freezer. Check for ice build up. . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Sep 09, 2009 | Freezers
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
Kenmore upright freezer
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
629 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
