RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Nov 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HD50LPW42YX2 Projection I had the wrong model in the first post. Bulb checks out OK TV turns on - green light on front is steady Bulb and fan do not operate. Sound is good
Mark Hammonds
Level 2:
  • Expert 61 Answers
  • Posted on Nov 22, 2008
Mark Hammonds
Expert
Level 2:
Answers
61
Questions
Helped
16098
Points
121
You could be looking at a problem with your power supply board not hard to replace pretty reasonably priced board definetly needs a tech to look at it
1helpful
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Hello, I have the KDS-R60XBR1 60 inch TV. The green light flashes about 40 times and then the red light flashes about 10 times (then nothing). When the green light is flashing, you can hear the TV trying...
First, if you have the manual, open it to troubleshooting, if you don't have it; www.sonystyle.com then click on support, then manuals. you can download it for free. The manual will decipher the flashes for you to narrow down your possibilities. The three main problems in the Sony lineup are the optical block, the bulb, and the fan. The fan is the only real obvious one that can be fixed quickly. When you turn on the TV, the fan should click on ( may vary depending on your main setup from TV menu) However, if you have any compressed air (dust off) etc. The fan is on the rear of the set on the right lower 1/3rd (looking from behind set) Location is in the manual too. If the fan can't turn on, the TV will shut down. Also, go to this site for further help from "Sony"
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-problems-by-TV-model
Hope this helps. If you need further help, post a comment and I will help you further.
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
23helpful
5answers
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
1helpful
TEMP or BULB light aren't on and Bulb isn't burnt out So whats causing the TV not to turn on
Probably the ballast if lamp is ok.If there is not even a standby light the the power supply.
No picture, no sound
The green steady power light is a good thing, how old is the TV?
If you are routing your audio and video through the audio receiver, make sure that the inputs are correct on the display of the receiver, ie. IF you are planning to watch your DVR and it is hooked up on Component 1 for video and Coaxial 1 for audio, make sure that the receiver is still programmed for this in the input of TV/Video 1 or whatever the input. I have ran into this on countless occasions, simple fix, but a headache until it is tracked down. Double check the connection to the TV as well.
1helpful
2answers
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
2answers
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
