Question about IBM ThinkPad T20 2647 Notebook
I was given a think pad 2647 and I can't get on the internet.
I hooked up a direct telephone line and it says it can not detect a dial tone. It has two pc cards. One is a noteworthy, 56 K modem pc card and a 3 com Megahertz 56K cellular Modem PC Card. I also have wireless internet that I use with my regular lap top. I don't have any handbooks or owner's manual. Can you help?
  • mbernice314 Nov 19, 2008
    does the think pad have an internal modem or do I have to purchase one. I don't have any modem other than my wireless.
    Sergeant:
  • 237 Answers
It may not detect it automatically. You will need to configure your dial up modem if you are trying to connect to the internet that way. Go into the network connections and go through the wizard there. It should ask you for the telephone number to dial for internet access so have that handy. If you don't get that box, you went to the wrong area.
Posted on Nov 19, 2008
Fax says it is off hook, what should I do?
The fax machine can't detect a dial tone (from a POST line). Since the Pixma MX420 doesn't have a handset, you may need another telephone to check your line. First, make sure that the telephone cord to the wall jack is connected to the RJ-11 port marked L. This is the lower of the two ports on the all-in-one printer. If the cord is in the wrong spot, swap the connection. That could solve the issue. If you have a telephone plugged into the upper RJ-11 port, check if you hear a dial tone. (Connect your test phone here if you haven't had one connected and check for the dial tone.)
Next, unplug the RJ-11 line cord and plug it directly into your test phone. Do you hear a dial tone? If you do not hear a dial tone, try a different RJ-11 cable. If the problem is solved, connect this cord to the lower port on the MX420 and see if the fax continues to give the "offline" message. If you still have no dial tone, take your test phone to another jack and try again. Find your incoming phone service box and check if that has a RJ-11 jack. If it does, you can test for a dial tone there. If the box doesn't have a RJ-11 port, you can have your telephone provider check the service.
If there is no dial tone at the service box, then your telephone company will fix the external problem for free. (With copper telephone service, sometimes rodents damage the wires. The provider has to fix this.) If you had a dial tone at the service box or another jack, then you have an internal wiring problem. This could be at the jack or inside a wall. If you take off the outlet cover, you'll find the wiring for the jack. This will either have screws holding down the stripped ends of the conductor wires or a punch-down keystone (with un-stripped wires). For the jack with the screw terminals, determine if any wire is loose/broken and strip a new section of wire. Then re-secure the wire under the correct screw. See http://www.lanshack.com/wire_phone_jack.aspx for a diagram. For the punch-down keystone, you'll need a special tool to reconnect the conductor wire. This tool is available at most hardware stores in the electrical wiring section.
If the problem isn't at a jack, you'll have to try to find the broken wire and replace the wire. Your telephone company's service technician will fix the problem for a fee.
If you have an internet connection with a DSL filter, you should check if the filter is damaged. This can lead to the above problems. If you have switched to a VOIP service, you'll need to make sure that it is compatible with the POST connection for the fax machine.
I hope this helps.
Sep 13, 2015 | Canon Pixma MX420 All-In-One Printer
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I have two dell laptops that are having the same problem of no dial tone
First of all, be sure that the connection you have configured on the computers are Dial Up connections.
If you have restrictions activated on the telephone line, removing them might help. Some other services of your telephone provider can also prevent your modems to properly detect the dial tone. It might be worth to take a look in that direction.
It might also be a problem with the telephone line. Try also to dial the number normally entered in the dial-up connections. You should hear a ringing tone shortly followed by noises similar to a fax machine. If you hear this, you access correctly to your providers dial up server and the problem would be with the two computers.
Apr 28, 2011 | Dell Computers & Internet
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
Lost dial tone and phone service
Your phone line might be connected to Telephone 1 not 2. That could be the reason why you are not getting a dial tone.
Nov 22, 2009 | Arris Touchstone 450a (CM450) Modem
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
Note: Press the keypad numbers to use an automated answering system.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
My printer will not receive a fax saying "phone off hook". There is no phone on the HP2410, and the phone is on the hook.
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver is off the hook (the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message. Checking the phone line The most common reason for this message is when a dial-up modem is accessing the Internet on the same phone line. Just as two phone calls cannot come in at the same time, two devices cannot use the phone line at the same time. If a broadband modem (such as DSL or ISDN) is on the same phone line and the message appears all the time, please contact your Internet provider for assistance. Even if a dial tone is present when listening to the phone line, the HP product may detect the broadband data connection at the higher line frequencies. Broadband modems must have a line filter installed to work correctly. Contact the telephone company for assistance. Please follow the directions below to verify functionality.
  1. Verify that the phone cable going into the HP fax product from the wall jack is a two-conductor cable type, not four-conductor. A two-conductor cable, like the one that ships with the HP product, has two copper leads in the connector. The connectors are usually clear, making it possible to see how many copper leads are inside the cable. Replace a four-conductor cable with a two-conductor cable.
  2. Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. If the message persists, see the "Problem still exists" section below.
  3. Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Continue with the steps below if a dial tone is present.
  4. Plug the phone cable back into the HP product and hang up any phones with a lifted handset.
  5. Disconnect, one at a time, other phones and devices using the same phone line. Check the HP product display after disconnecting each phone or device. If the message clears after disconnecting a phone or device from the line, the problem is with that phone or device.
  6. If the message still exists after unplugging all other phones or devices, see the "Problem still exists" section below.
  7. Problem still exists
  8. If the problem still exists after performing the steps above, the line interface unit (LIU), the part that the phone line plugs into, may be defective or the HP product may need to be serviced.
Jan 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
IBM ThinkPad T20 2647 Notebook Logo
129 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
