Question about Dryers
DRYER LINT I have lint that has collected in the bottom of where the lint trap goes. I want to clean it out. I have used a vacuum to get as much as I can however, I can see much more. I need to know how to get the front off so I can clean it all out. I have a Maytag front load dryer the model # is MDE2706AYW the Serial # is 11523841JP It says Heavy Duty/ SuperSize Capacity/ 7 Cycles on the control panel.
  • tamann67 Dec 04, 2008
    the lint trap on my GE DBLR333GT1WW WAS DAMAGED AND LINT IS UNDER NEATH THE DRYER DRUM AND I NEED TO GET IT OUT.
    HOW DO I GET THE FRONT PANEL OFF?? OR HOW DO I GET THIS LINT OUT MY HAND DOES NOT FIT IN THE AREA.
    Sergeant:
    Champion:
  • 324 Answers
You can purchase a brush for the dryer, you can reach down further with it.
Posted on Nov 19, 2008
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
Item feel into lint trap, how do i remove?
Get one of those attachments that goes on the end of your vacuum. They are made to clean out the lint trap channel.
May 14, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
F @ P DEGX2 lint trap problem
If you are collecting more on the outside of the house means the lint filter has a tear in it and the lint in being pulled through the tear and pushed out the exhaust. It sounds like you need a new filter but this isn't cheap. If you do it your self it will run about $70 if you get a repair man it will cost about $150.
Feb 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Oct 22, 2009 | Kenmore 62602 Electric Dryer
Water in dryer
Clean out the lint trap and the vacuum the slot it goes into. Also clean out the vent hose and vacuum out all of the lint inside the dryer where the hose attaches. This is normally caused by lack of air flow.
Jun 21, 2009 | Dryers
Odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
Is it possible that the automatic sensor can fail on a dryer.
hi, Sounds like everything mechanical and electrical is working. The sensors are located on the outbound air ducts. You may be able to improve things significantly by removing the dryer vent where it attaches to the rear (or side) of the machine, and cleaning the tube going into the machine. While you have it removed from the vent, remove the lint trap, use your vacuum crevice tool and clean the trap area. If you have the ability to blow air through the trap area, blow it through the crevice tool so that you are as far beyond the screen area as possible. Be warned that it may blow dust and lint from the vent, covering it with a piece of nylon stocking will catch most of it. The object of this whole exercise is, the exhaust air ducts collect dust and lint which collect moisture from the damp items, the sensor reacts to this so cleaning out as much of it as you can will help. Good Luck to You!
Feb 17, 2009 | Kenmore 63942 Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
