Question about Car Audio & Video
Radio presets on my toyota camry 1998 will not hold any more.
When I turn the car off, if I had the radio on, it isn't on when I start the car next time and my station presets won't stay programmed. Is there a battery that is in the radio that keeps the presets alive? I would have thought it got power from the car battery. This seems to be a common problem. I have seen a lot of people with the same problem on line. I just have not seen a solution.
  • pinnellt Nov 24, 2008
    Sorry for delay in answering, fuses are not the problem since occasionally it will work fine. Radio and everything else works fine, as long as the car is on, I can reset the radio stations and the new pre-sets will work fine as long as I don't turn the car off. When I turn the car off and then back on, the new presets are gone and the radio does not come back on when I restart the car unless I manually turn it back on. Are we sure there is not a battery in the radio that should be keeping the memory set?
  • irispiral Jan 06, 2009
    I am having the same problem with my 1998 Tercel. I noticed today that after having the 4-ways on for 10 minutes, the car was also difficult to start. Does this indicate a fuse or battery problem? Or either?
    New Friend:
  • 74 Answers
Be sure when setting presets you hold the button down for at least 3 seconds to set the channel, if you are doing this correctly, you may have a blown back up fuse under the hood. there are 2 fuses for the radio one is marked radio and is inside the fuse pannel on the inside of the car the other is for memory back up and located in fuse box under hood may be marked B/U just check them all to be sure!
Posted on Nov 21, 2008
2009 Camry. Radio display scrambled, but then seems to fix itself. When scrambled sometimes the display disappears altogether. Whe scrambled I can't change channels with preset buttons. Btw, my outside...
just the internal display.
that means radio is bed. if sound holds and stations hold and sound good.
my gosh, both died same day?
check fuses first. as always for ever and ever.
try to say what works good or bad on the radio in all modes.
all modes. Am/fm cd or ? usb port, if optied
is radio stock? oem original, lock box stock.?
Jan 31, 2015 | 2009 Toyota Camry XLE V6
The radio in my 2000 Toyota Camry turns off when the engine is off overnight and looses it's programing. When I start it in the morning, although I did not turn it off, the radio is off and none of my...
There a two power wires to the radio, one to power the radio (which appears to be working) and a second to keep the programming (which does not appear to be working). Check that all the fuses are good (there is probably one for the memory).
Jul 20, 2011 | 2000 Toyota Camry
How do I set the presets on my radio. I don't have a manual and can't figure it out
start the car turn the radio on scroll to the station you want then push and hold the preset button 1 thru 9 untill it beeps then go to the next station you want to set and do the same.
May 15, 2011 | 1999 Jaguar XK8
How do install a 1998 toyota camry radio into a 1990 car?
Just use the install guide with the property plug connections:
- Uninstall Toyota Camry 1999-2000
- Install Toyota Camry 1987-1991
For reference to Toyota radio wire harnesses, review this wiring diagram for 1987 and Newer
Hope helped with this. Good luck.
Nov 09, 2009 | Car Audio & Video
How to hook up a 1998 radio into 1990 toyota camry.
Depending on what radio you are putting in, You may need an adapter pigtail. Read the directions closely.
Nov 09, 2009 | 1990 Toyota Camry
Where is my falsher relay located? I have a 1998 Toyota Camry CE. HELP!
With your key on give a left or right turn signal. Try to listen and pinpoint the clicking of the turn signal flasher. Once you locate the turn signal flasher, your hazard flasher will look just like this and should be mounted nearby, typically next to it. The flasher simply pulls out and the new one just pushes in
Jun 12, 2009 | 1998 Toyota Camry
My 2000 Toyota Solara radio has started to lose a strong signal.
Check mounting surfaces at antenna. Corrosion or looseness and the antenna loses its ground to the body.
Oct 27, 2017 | 2000 Toyota Camry Solara
Car Audio & Video Logo
918 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
