Question about Maytag MER5775Q Electric Kitchen Range
How to change a three prong plug in to a four prong plug in?
I need to adapt my plug from one ground to two ground wires.
  • 370 Answers
White and green go to the middle terninals and red and black to the outsides (doesnt matter which side)
Posted on Nov 19, 2008
Can i switch the plug on my dryer
If you change the plug on your dryer to a three prong and plug it in that way it will work, however it will not be up to the latest electrical codes where the dryer needs to have its own ground, not share that ground with a neutral. I would recommend running a new wire 10/3 with ground with a new four prong outlet (note: if you already have the 10/3 wire there you can just as easily change the outlet; red and black are hot wires, white is your neutral, and the bare copper is your separated ground) . However if you would like to just change the plug to a three prong you have to make sure your ground bar is tied to your neutral bar and there you only have three wires, 2 hot and one neutral.
May 03, 2010 | GE DBXR463EBWW Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Changing dryer plugs
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Sep 09, 2009 | GE DCVH515GF Gas Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 | Dryers
Switching electrical plugs
it sounds as if your plug configuration is for 220 volts. that means that all wires are needed to operate the unit. white is the common and red and black are both power leads. in other words...the red lead provides 110 volts and the black provides 110 volts, and the white is the common for both circuits. and of course the ground is for curcuit safety
to change to a three prong plug the ground must be sacrificed but with shock risk. i suggest a seperate ground wire run to an adequate ground.
a typical three prong plug will mean that the two prongs closest to the edges are the two power leads and will use the red wire on one and black wire on the other.(doesn't matter which one goes on which prong)
the white will go to the center or usually odd shaped prong. be sure and be safe!
hope this helps.......................jay
Mar 20, 2009 | Bosch Nexxt 800 Dryer
From three prong to four prong
Hello There,
your hooking up 2 Hots 1 Neutral and 1 Ground
240v
you need to consult a electrician for reason that 240 is a very high voltage and will kill you.
your outlet has to match your plug and how its wired into the Panel
Double Pole Breaker 50amp no less
2 hots go to breaker from outlet red / black
1 neutral goes to neutral bus bar in panel from outlet
1 ground goes to ground bus bar in panel from outlet
that equals your four wires
Mar 20, 2009 | Whirlpool LER5636P Electric Dryer
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
I have a 3-prong plug on a 14-year-old dryer. Now must change to 4-plug. Is that possible ... and if so, how?
A three Prong contains L1 (Line1), L2 (Line2) and N (Neutral). A four prong will contain L1 (Line1), L2 (Line2), N (Neutral) and G (Ground) typically a green wire.
Connect the three wires as normal, connect the green wire to the screw provided on the cabinet.
Jul 04, 2008 | Dryers
Maytag MER5775Q Electric Kitchen Range Logo
225 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
