Modem Turns Hot
This one is another issue... please help, why the hell is my modem turning hot and not hot it is really hot.... like i just cooked my pancake!!!
is that normal....???
  • 78 Answers
the modem will turn warm during the usage.. but it should not turn hot as your pancake pan. If you have the modem plugged in to your power bar.. make sure it is directly into the wall socket. and then check..
was i help ful?
Posted on Nov 19, 2008
My N150 route gets very hot I've heard this can slow DL
How hot is this, really? Most technical devices are designed to withstand a certain amount of heat. If you feel like things are getting too hot under your feet and there's a real fire hazard - call the shop that sold you this modem. That shouldn't be happening.
Anyway, theoretically speaking I believe that more heat should actually speed up electrical circuits. There are a real, proven scientific theories that explain this. So whatever you heard: no, it isn't true. I can imagine the idea about a modem underclocking itself when it senses a temperature increase, but that would be the first modem I ever heard of doing that.
Mar 13, 2011 | Computers & Internet
My modem randomly resets and no internet.
either the modem is going out or its a problem with your internet provider. before calling to complain to the internet provider. run down to your local walmart or electronics store and pickup a modern if you have the same issue its your internet provider.
i delt with a modem that was causing a similar issue. the problem ended up being the modem was running hot. i modified the case and added an external fan and the problem went away.
hope this helps. good luck
Mar 03, 2017 | Thomson RCA DCM245R Modem
When Jeep is warm/hot. Makes noise when in
I have the same issue... I have a 94 grand cherokee limited 5.2L ! i have been through hell with this issue new rearend ... expensive fluid and etc. After all this it turns out its the transfer case .... it has a viscous coupler in it witch acts the same way as a clutch when the vehicle is cold no effect until it is hot, then all hell you think your breaking drive shafts or you have a flat tire with clunking noises!!!! so i hope this will help you! i would go into more detail but im sure your mechanic will explain it in more detail!
Apr 09, 2010 | 1994 Jeep Grand Cherokee
Not getting ethernet connection from the router to the modem
Please check your router's power is working or not.
if your router's power adaptor is OK the possibilty is your router's motherboard is faulty.
need to go service center.
Mar 30, 2010 | Zonet ZSR1134WE Wireless Router
Motorola MSTATEA takes long time to "reconnect"
Check the speed and call ISP tech support to run the line test
Before calling them do a complete power cycle
Turn the modem off and the computer off and router if any
Wait for 30 seconds and turn the modem on and wait for the lights to turn solid
Once ready turn router if you have else computer
Delete the temporary internet files browsing cookies,cache memory.
If the modem turns too hot after running for an hour please replace the modem
DSL light blinking green indicates that there s no proper signal to the modem
Check the wall jack for any loose contacts
If you have any filter check them too
Isolate them and try with it
Change them if possible
Feb 06, 2010 | AT&T High Speed DSL Modem
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Losing Connection
Its quite possible that your modem is overheating. This would lead it to reach its emergency shutoff temperature. My recommendations would be to temporarily try it in a cooler place in the house with maximum ventilation possible, for instance in your basement (if you have one) or possibly on a freezer or next to an air conditioning unit. A few possible long term fixes include:
  • Mount a passive or active heatsink onto the CPU of the modem.
  • Cut (many small or some large) holes into the housing of the modem to improve the airflow.
  • Mount a fan on the top of the modem that sucks the hot air out the the housing.
If after trying those solutions and the modem still overheats, please feel free to leave a comment and I'll get back to it as soon as I can.
Aug 12, 2009 | Comtrend CT 300 (CT-300) Modem
I have a siemens speedstream 4200 modem. It gets very hot to the touch, is it good to turn the modem switch off sometimes when you have your computer shut down?
Sometimes it's normal for some modems to be very hot. Make sure it's no in a very enclose space. And yes it's ok tp turn the modem switch off sometimes if you have to shutdown the computer. Just be sure to turn on the modem first then the computer in that sequence when you need to use them again.
May 08, 2009 | Siemens SpeedStream 4200 (13A4200001)...
My Motorola modemDtyle MSTATEA provided by ATT Yahoo sbcglobal get so hot and stays hot all the time. Is this normal or is somethin wrong with it. I had another modem from them and it was also very hot. I...
The computer has nothing to do with the modem, the reason for these getting hot is because the use resisters and capacitors and there is no fan to cool these off, Solutions are keep room cool, modem free of dust and debris, and last but not leaast rest assured this has nothing to do with your cpu geeting hot. If this information is useful to you choose the fixya rating and Have a nice day thanks for using
Apr 24, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Acer laptop Aspire Model the battery turns hot.
Laptop batteries do get warm when they are in use or charging but not so hot to cook eggs.
This is dangerous and it could explode and catch fire.There could be a problem with the charging circutry or a faulty battery. Get it checked out.
Nov 18, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
