Question about HP OfficeJet 4215 All-In-One InkJet Printer
It says ''insert color cartridge''
I have done everything as the instructions stated.but still my printer wouldn't work.please help...
  • 1 more comment
  • rosina428 Nov 29, 2008
    how can I get instructions for 4215?
  • rosina428 May 11, 2010
    When I try to print from the computer, it says fax and I can only fax.
    How do I change that
  • comment
    comment May 11, 2010
    Can you be more specific as to the exact error, and what you have done to correct it thus far?
    Are all the cartridges in place? Are they New or Refills?
Here is what worked for me on an hp officejet 5510 after all suggestions I found googling failed:
Turn off and unplug your printer. Get a bright flashlight and set it down so that it shines on the printing device that holds the cartridges throughout the following process. If necessary gently push the printing device toward the center so you can easily see and access it. Remove both cartridges, even if your printer indicates a problem with only one. Now align your eyes so that you are looking squarely at the empty cartridge spaces, not from an angle. If your printer has the problem mine had (and it arrived this way new out-of-the-box), one of the verticle rungs that hold the sides of the cartridges in place is not exactly perpendicular to the printer, but slightly slanted or curved. Compare the (incorrectly) slanted rung to the others that are (correctly) perpendicular. The pronged "foot" at the bottom of the slanted rung is not standing in its corresponding "shoe" (slot). Gently slide the "foot" into its slotted "shoe" so that the rung now stands perpendicular to the printer and parallel to the other rungs. Now click the cartridges back into place. Plug your printer in and turn it on. This fixed the problem for me.
Posted on Dec 26, 2008
  • 3 Answers
I have learned that Office Depot refills do not work on these printers. Do not use refills even if they are packaged for sale.
Posted on Dec 03, 2008
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
I just put all new ink in my printer and will not print. Unplugged it to re-boot it, still won't work. If i copy something by hand will not print, if i copy something from computer it does not...
be sure that you remove the tape from the cartridges before you insert it in the printer, it has a color pink attach to the tape remove it slowly then insert the cartridge to the printer,
Aug 03, 2011 | Computers & Internet
Trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
May 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
Copier states to ''insert color cartridge''
When you installed the new cartridges, did it ask or display if you "installed a new ink cartridge" press the ok botton to rest the cartridge back to new. Then it will ask you to aline the cartridge and it will print a test print and ask you to place the print out on the glass. Do the same for the next cartridge..... I have one question, is this a new problem with the new cartridges????
Mar 24, 2009 | Office Equipment & Supplies
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I loaded the black ink like I have done so many times before, but a window is coming up saying it does not recognize my color catridge and will not print. I dont even have a color cartridge in the printer.
Some printers will not print while missing either of the cartridges, was the printer working without the colour cartridge before?
Try inserting a colour cartridge and see if that helps.
Dec 09, 2008 | Canon PIXMA iP1600 Printer
HP 1610 Won't Recognize the Color Cartridge?? Please Help!
i don't know who checks these messages, but I have the exact same problem, also with my mom's printer. it is no longer under warranty so HP wants to charge me thirty dollars for them to tell me how to fix it over the phone. no thanks.
Jun 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Dell 942 all-in-one printer problems.
The problem is simple. Try inserting your old in cartridges. If the old ones work, the ink cartridges are defective. Contact Dell and get these replaced.
Otherwise the printer has a problem. try cleaning the metal contacts of the ink cartridge and the ink carrier.
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
Printer wont print color????
Possibly a bad cartridge, bring it back and get you a new one, if it still doesnt work its possible there is an obsticle in the cart. holder blocking the contacts.
Sep 14, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HP OfficeJet 4215 All-In-One InkJet Printer Logo
48 people viewed this question
Ben Johnson
