Question about AOpen F2705 17" LCD Monitor
Monitor goes black as if the light went out.
I can see data if i look very closely.
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    New Friend:
  • 17 Answers
Bad lamps you may check your monitor ccfl maybe or the inverter.
Posted on Jun 03, 2013
Monitor goes black seconds after showing desktop
Does your monitor go black because it went to sleep, does it turn off? Do you have any lights on the monitor to indicate what it is doing?
Also I would boot into safe made by rebooting the computer & tapping F8 when the bios appears. You should be prompted with several options, one of which is "Safe Mode". Choose this & report how the monitor behaves.
Jul 24, 2012 | Acer X193W LCD Monitor
Screen gets black
Typically the graphics card went out. Other possibilities include, loose monitor cable or short in the cable, or incorrect graphics driver installed or missing, or monitor is shot (least possible). Things to look for: When booting up are you able to see words in the monitor or is there a series of non-regular error code beeps? If beeps then most likely your graphics card is either loose or fried, or incompatible. If you it works fine, but the light on the monitor turns orange and screen goes black, then it's most likely a loose monitor data cable or there is a short in the cable, or monitor's power cable is loose. Then check both connections, power and data on the monitor, and also where it hooks to the computer make sure it's screwed in snug.
Jan 13, 2012 | Computers & Internet
My monitor works fine for weeks than suddenly just goes black! I turn it off and back on and it only stays on for about three seconds than goes black again! The power light stays on!
take off the monitor data cable from pc and try to turn monitor on if appears a smal square on the screen that mean your monitor is ok , and the black screen reason maybe data cable or vga card.
note : your monitor resolution is 1680x1050 some times wrong resolution cause like this problems
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Acer P221W LCD Monitor
My screen just went black
Hello, if the Toshiba monitor went black: 1)if there is power from the monitor, check power cable and data cable 2)make sure that its properly connected to the computer 3)make sure computer is on and there is an activity from the computer 4)if the is sound from the computer try a known good monitor if that will work 5) try this Toshiba monitor to a working computer 6)try checking the monitor maybe the back light is busted get a flash light point it directly to the screen it self check if you can find something 7)if all is done bring monitor to a repair station if in warranty manufacturer Thank you for using Fixya
Mar 06, 2011 | Toshiba Computers & Internet
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Computer monitor went black with small white blinking light on the upper far left corner....help?
your monitor appears to be working. Do you see any kind of text after rebooting? Was a CD left in the drive?
Unplug the monitor data cable from the computer, it should nag you about NO SIGNAL
Apr 04, 2010 | HP 2009M Monitor
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Syncmaster 226bw goes black
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
AOpen F2705 17" LCD Monitor Logo
90 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
