Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Will not turn on
RCA model D61130,chassis ctc211a,service number D61130yx1, serial C106C105C. Tv turned off and will not come back on.the small light on the front panel does not even light up.TV is 6 years old and have had no problems until now. there has been no warning of any problem coming. I enjoy watching this TV and I just cannot afford to replace it. do you have any suggestions as to the problem.I am a lic. mechanic and am use to working on delicate electronics and high voltage. I f you could give me an idea as to what to check it would be appreciated. I only wish that i could find a service manual for it as i would check it myself. Thank You mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
    New Friend:
I have a 20 inch RCA Latin heat and power cord into blue and brown wire coming from the back of power which was negative
Posted on Nov 22, 2015
    Problem Solver:
  • 61 Answers
If it is the chassis im think it is you will have to take the back off looking at the chassis the very front right corner there is a board apporx. 6in. long 2,3 in wide look at the fuse if it's blown take the small board out make sure set is unplugged it just clips in around the edges with plastic clips there are a set of diodes toward the opposite end they make check shorted if so replace there is a part number on the side of the diodes call some shops or go to fry's online maybe
if it is not blown there are 2 wire cable that comes from that board all the way up to another board called the deflection but the easiest way to check it is your board at eye level to the right those wires go there also a brown and green or blue wire to the top left hand corner of that board check with a volt meter on D/C setting for 300 to 340 volts if you have those volteges you could have a problem on the deflection board
Posted on Nov 22, 2008
I need the serial number for an RCA 22" tv with DVD model number LED22B45RQD
Its serial number should be with its back cover; either on a sticker or hard printed. If not, can get this information by its chassis inside.
Electro help
Oct 20, 2014 | RCA Televison & Video
RCA D61130 power light blinks green tv wont come on
Time for it to go to a shop--it is unlikely this brand/model will get fixed in the home.
May 18, 2012 | RCA D61130 TV
Need part no. for cr14710 tv model no. D61130yx1
Part is marked as no longer available--you may be able to find it on the Internet-----------
RCA part number is 243846 (suggested list is $4.95)
If you cannot find it I would suggest you contact PTS electronics--they repair/rebuild all kinds of circuit boards and may be able to help you.
SD TECH
Oct 03, 2009 | RCA D61130 61" Rear Projection Television
Access Service menu
Hey there!
Its really easy to do, but write down any settings before you go changing them..
1. Turn off tv.
(use buttons on tv for this)
2. Push volume down and channel down both at the same time, and hold them for about 10 seconds, or until the tv turns on.
Jan 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52130 CHASSIS CTC211A PROBLEM
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Mar 27, 2008 | RCA D52130 52" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
207 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
