Question about FIC AM 37 Motherboard
Power to the mobo
I have a problem with the power ! sometimes I turn it on the fans click on
then the computer beeps and shuts down it only stays on for about 2 sec
and shuts down to the point that it won't turn on at all
would it be easier just to buy a new mobo because I think this one is trashed
  • 37 Answers
Without having the specs on the motherboard or knowing how old it is, it's difficult to say if it is beyond repair. Although my experience with computers shutting down that quickly while attempting to boot have been a problem related to processor overheating. Processors get very hot within seconds of powering on. If the processor cooling fan or the thermal paste is not working as intended the system will shut down quickly. You may want to check those two possibilities before purchasing a new motherboard.
Posted on Nov 20, 2008
Trys to start but when its loading it turns off...its a dell inspiron 1545 i tried to start it on safe mode and nothing it turns off
I have some things I might be asking you to do first. Because this might be a heat issue but just to make sure try these steps first.
Remove batter and charger.
Hold down power button for 20 seconds.
Remove the RAM or memory chip. By doing this the computer will give you 2 beeps and a pause then another 2 beeps just right after you power on the computer. While computer is beeping check if the laptop will turn off automatically.
If yes then HEATSINK, THERMAL PAD and FAN needs to be replaced.
If the laptop stays ON and beeping and beeping it means it might be the RAM. So test the RAMs one at a time. Run the computer using 1 RAM at the moment then try the other slot. Do the same thing on the other RAM.
If still turn off with each RAM tested the have the MOBO or PROC replaced.
May 01, 2011 | Dell Inspiron 1545 Notebook
I have a Gigabyte EX38 DS4 motherboard. A few months ago the power light light would blink after I shut windows down and it wouldn't turn on again. If I unplugged the computer for a while it would stop...
As you may already know, your computer will shut down after power on if if the power supply does not receive a power good signal from the motherboard. Since you already tested the PSU in another computer, and you know the PSU is good, either you have a bad mobo or some device connected to the power supply is draining excessive power from the PSU and causing it to shut down.
Try removing the 4 pin pin power plugs from ALL devices, such as the floppy drive, CD drives etc.
If the system stays on when you power up, then you can isolate the faulty device by re-connecting them one-by-one. If the system still shuts down your Mobo or CPU is bad and you might want to take it to a PC technician to determine if it's worth fixing.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 18, 2011 | Intel Motherboard
Power button does not light, fans run but computer does not send signal to monitor. Replaced power supply, no change. Put in new graphics card, still does not generate video that would allow me to change...
no HP PC stated just a MOBO. must we guess?
no the power button is just 2 wires, a digital line and ground
it must be plugged in to the correct MOBO jack.
in fact i can turn it on with a simple jumper wire, there.
i guess you found the board, in garage sale, just tossed in a box?
if the local vga jack and added in VGA card both fail then its a mobo issue.
im googling for you.
lets see what POPS
Compaq Brio ATX PGA370 New D7580-60003 *
This motherboard is only compatible with Celeron 400 CPUs
With integrated SiS Super AGP graphics controller?
takes 1 good RAM stick.
if the fan fails to stay on, that means the PSU sees errors.
mostly sees shorts on MOBO(remove things to find it)
that one old mobo is rare, now.
is the coin cell at 3vdc, or below 2.9v, if yes, needs new one.
HP has zero data (information) on this old mobo or the COMPAQ BRIO anything.
https://www.youtube.com/watch?v=3at_Ev2kOoI
Aug 13, 2017 | HP (D7580-60003) Motherboard
No display on monitor
if you have a video card in it try connecting it to the motherboards vga/dvi and see if you get any video. if not it could be ram/cpu or mobo if its not beeping my bet is on the mobo
Feb 14, 2010 | Gateway Essential 400 PC Desktop
The motherboard the shut down when switched on
Check heatsink/fan for CPU first. If this is Ok then try a new power supply.
Feb 02, 2009 | ASUS P5GZ-MX Motherboard
Stand by
Standby does not turn off the computer. It reduces power consumption but does not turn the CPU off or the power supply. Because the cpu is still on the cooling fan stays on to cool it. If you want it to turn the fan off or be silent I suggest using hibernate or shutting it down completely.
Feb 01, 2009 | E-Machines (308714) Motherboard
Emachine not turning off.
you can checkit by unhooking it on the inside from the mobo panal just remember where it ogoes back take a small flat head and cross the two prongs it comes of off then shut it down if it works look on ebay for a complete front panel with switch or order from emachines.
Oct 29, 2008 | E-Machines eMachines Desktop PC
Biostar motherboard or processor dead?
have you also tried different video cards? or the onboard built into your motherboard?
Jun 11, 2008 | Biostar P4M80-M4 Motherboard
Computer shuts down but does not turn off
Mchem, you actually have 2 separate issues going on there.
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
  • click ok
  • click ok
  • Open control panel > open power options
  • in the power options properties, select the advanced tab,
  • in the power buttons section,
  • When I press the power button on my computer: click on the drop down menu and select the shut down option
  • click ok
Sebastien123, you only need to run the first part of this solution.
Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
Power switches off
Try changing refresh rate or resolution. You might be using one that your screen can't work with. good luck
Jun 09, 2006 | Philips 170C4FS 17" LCD Monitor
FIC AM 37 Motherboard Logo
155 people viewed this question
Top FIC Computers & Internet Experts
David
David
Marvin
Marvin
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
