Question about Kenwood KRC-X957
Kenmore washer drum off its axis. How do I fix it and open the dr
How do I open the drum section to fix the problem?
Boss DR-3 Dr. rhythm LED screen lights up by does not show any information. what can I do to fix problem?
take it appart. there is a conductive rubber between lcd pannel and the pcb use widow washer fluid without amonia to clean it
Jul 20, 2016 | Roland Boss Dr. Rhythm DR-3 Drum Machine
Machine bangs when on spin
Washing machines are just metal drums spinning in an axis from a motor with a belt (like how your vacuum spins the front brush). The pulleys to guide the bey can wear out. Open up machine's back and you'll likely see the problem. (have a flash light)
Here's videos and parts. Check elsewhere as you can likely find cheaper but they aren't terrible for prices.
Kind Regards,
Scott
How to Repair Your Washing Machine
How to Fix Noisy Washer
Feb 11, 2015 | Washing Machines
Washer drum loose and banging
There are springs that support the drum, open it up and check them out.l
Nov 25, 2013 | Washing Machines
During the spin cycle, the drum seems to spin off the axis slightly causing a very loud banging noise as it makes contact with other parts of the machine. Is that an easy fix?
it sounds like you drum support or spider as it is called may be cracked or your bearings are shot the fix is time consuming and will take patience as you dismantle make sure you take note where all parts fit if you are not confident call a reputable repairer cheers
Nov 05, 2009 | GE WSXH208A Front Load Washer
Samsung multi function printer 2160
Open Drum cartridge , there are four dr. blades for 4 color , clean it...
Mar 15, 2009 | Samsung Laser Multifunction Printer Toner...
Dryer drum not rotating
Drill holes all the way through the drum. Use carrage bolts to reattach the Bearing block through the drum into the block. Use lock washer and or locktite.
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
