Replaced fuse I replaced the fuse and all was right with the world 3 hours later it went out again is there something else I need to replace ( lucky I bought 2 ) HELP
  • kputens Nov 25, 2008
    Help me out when you say did you reslder the flyback connections what does that mean. I unsoldered the fuse and replaced it and that was all I did was there something I missed.
  • kputens Dec 01, 2008
    Replaced the tube again and it blew again. My son who works on all of his own cars decided because it was a type of fuse lets by pass it with a jumper and what to our wondering eyes did happen IT WORKS so far it has been going for 5 days with the jumper with no problems. We did leave the back off so that we could watch and make sure there was no fire hazards. I don't know if you want to use this as a fix or not but so far so good I will let you know if there are any problems.
    Thanks kputens
  • 1,030 Answers
Sorry to here this... I have to ask... Did you resolder flyback connections. I have found if i didnt the fuse would blow within a day. Now if you throughly resolder the connections then there definatly other problems.. Bad ribbion cable maybe. I will admit i have not come across instance of other compnents causeing this. Is the fuse blown again? There is one case out of about 1000 of these i repaired it was a bad signal board...very rare though. let me know what happens.
Posted on Nov 19, 2008
  • Willie Howell Nov 25, 2008
    when yo removed the fl231 fuse you unsoldered it and put it in and soldered it back. NExt to that fuse is a large black compnent next to it with a large red wire coming from it. this is called the flyback. The main reason the fuse blows is do to poor connections from factory on this component. when i say resolder this i mean touch your solder iron to its connections. the pins for this s ussally in a circle. take some new solder and add to the connection. This should fix the cracks on this connection
Starter Fuse Keeps Blowing When I Try To Start My 2001 Camry
The starter has gone to ground. This is either a coincidence of age or the repair shop left something disconnected that has slapped around and grounded the starter or some of their other work has shifted around and done it. It could just be a coincidence. If it went to ground internally, it will need replacing. If something shifted and grounded it out, putting that something where it belongs and THEN replacing a fuse should fix it. Most shops reuse your starter on their new engine.
Apr 16, 2017 | Toyota Camry Cars & Trucks
History: 2 days ago the battery light came on. Car ran fine that evening. The next morning. The tach stopped working. a minute later the speedometer stopped working. Then, another minute later, the car...
Replacing the fuse the first time was the right move, becuase it could have been a fluke that it blew. Replacing it again and again was not! You should have found out EVERYTHING that the #2 fuse controlled and verified that the components weren't pulling excessive amperage (shorted condition). By replacing the fuse over and over, you might have made the problem worse by subjecting good components to something that was shorted.
BTW next time pick the oldest guy at autozone to help you, if the counter help knew their stuff they would have told you the same thing I just did!
Sep 04, 2011 | 2000 Ford Contour
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
2003 Toyota Corolla 30 amp keep blowing
it sounds like when the cat was changed they have trapped a wire or just moved one over a bit and its rubbing think about what items this 30amp fuse is protecting are any of the items close to the exhaust or around that area, i dont see the aftermarket starter doing this after 2 years hope this is helpful regards JR
May 17, 2009 | 2003 Toyota Corolla
try replacing the alternator.
Nov 25, 2008 | 2001 Chrysler 300M
XG-C50 Problem
Replace the fly-eye lens of projector.
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
