Question about Tools & Hardware - Others
Battery hot, new gas - trigger will not pull
When you engage the tip with the wood - makes all the sounds but the trigger will not pull - was still on first gas cartridge - replaced because thought it was the cartridge
  • David Ford
    David Ford May 11, 2010
    what kind of tool we talking about?
  • 195 Answers
This may seem silly but gun tip will not engage if right amount of fasners or not installed. Try adding more nails.
Posted on Mar 19, 2009
Starter clicks but will not turn engine over on 2004 Dodge Durango. New starter and battery.
Hi Mark
Sounds like you are doing all the right things.
We used to Load Test a Starter Motor by putting it in a Large Vice and connecting a known good battery with solid fat jumper leads.
When the solenoid throws the cog forward to engage we would use a 2 by 4 block of wood levered against the cog to try and stop the starter from spinning. The wood burns up under load but it quickly proves the Starter is functioning under load. Without using the engine.
Also you could try removing the spark plugs on the engine to allow the compression to escape. Make sure NO sparks around to ignite any fuel vapor.
The engine should spin over easily like this and you can hear & see if anything is binding up.
Hope this Helps!
Mar 03, 2015 | 2004 Dodge Durango
I have a paslode model IM250II 16 ga straight finish nailer that I bought used the gun fan and motor runs whin the trigger is pulled but it does not fire when the tip is pressed no pop no puff nothing I...
Fan running when trigger pressed is normal however to make it fire you need to press on the work probe first and the fan should start running, at this point the gas should be injected and pressing the trigger should create the spark to fire the gun, if all works as above but the gun won't fire check the gas, the metering valve on the can should have a yellow ring and when pressing the can nozzle on a hard surface, gas should be released, if not the can either has (a) insufficient gas, (b) the nozzle is not correctly fitted (c) the metering valve is faulty, if the can emits gas the gun will need to be checked for spark and the seals will need checking
Aug 21, 2013 | Tools & Hardware - Others
How do i use a spade bit?
I'm assuming you mean a spade drill bit?
For best results, try clamping a block of hardwood to the back side of the stock before drilling. When the bit approaches the end of the cut, it will be far less likely to blow through with another piece of wood to drill. However, if the stock placed on the back side is softer than the workpiece, or if it is not securely clamped to the workpiece, tear out can still occur.
To use a spade drill bit, mark the center point of the hole to be drilled on the wood, and install the shank of the bit into the drill. Align the point of the pilot tip of the spade drill bit with the mark on the wood, and adjust the angle of the handheld drill so that the shank of the bit is square to the surface of the wood. (Of course, if you're using a drill press, the bit's angle should already be square to the surface of the wood, unless your drill table is not square to the motor).
Depress the trigger of your drill slightly to engage the motor and turn the bit slowly. Hold the drill as still as possible so that the pilot point stays aligned with the mark on the wood. Because pilot tips can often "walk" away from the intended center point of the hole, some woodworkers will pre-drill the pilot hole using a small-diameter twist drill bit that is less likely to walk, and then proceed with the spade drill bit's pilot tip into the pre-drilled pilot hole.
Once the pilot tip is in place and engaged with the wood, increase the speed and proceed to drill the large diameter hole with the spade drill bit. Continue drilling until you reach the opposite side of the wood and the bit pokes out through the completed hole. Slow the speed of the motor, and pull the drill bit out of the completed hole.
For more details, check out my source: (link)
Mar 23, 2013 | YouTube Videos
I have a bostitch n62fn finish nailer that wont fire. when i pull the trigger, air comes out of the trigger assymbly. the gun is not jammed, and is receiving correct air pressure.
this may sound stupid but are you pushing it against the wood when pulling the trigger. it has a safety switch on the front so it will not work just by pulling the trigger.
Nov 12, 2011 | Stanley Bostitch N62fn Finish Nailer Parts...
Gun will not shoot nails completely;no matter what wood,thickness,etc.they drive all but 1/2"
May be due to broken tip. Easy to check. Remove nails and leave door open. With door open, lightly tap the nose of the gun against coiled rubber hose or soft wood. The driver should stay at top position. If driver falls to bottom of the cylinder, replace piston oring. Now press nose of the gun against old coiled up air hose or soft wood and squeeze and hold trigger. The gun will fire and the driver should stay in the down position untill you release the trigger (if not single fire trigger, if single fire trigger remove trigger and press the trigger pin with finger). While the driver is down, make sure that the tip extends past the nose about 1/4 inch (if air leaks past the nose in this position, replace lower bumper). If the driver does not extend past the nose, replace driver. Good luck
Jun 24, 2011 | Stanley Bostitch N75c1 Coil Sheathing...
My paslode wont shoot i cleaned the gun recently and oiled also the light is green and i compress the tip to shoot and it wont but the fan still comes on to vent the gas i also put a brand new gas in
strip it down again and put the battery in and whilst holding the nipple down pull the trigger (just mind your fingers as the fan will start) and as you squeeze the trigger see if sparks each time
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
My hitachi nailer wont fire
Start with the basics:
First check that the butane (or whatever gas is used) canister is full. If empty, put in a new one.
Second check to make sure your battery is fully charged to be able to fire the spark to work the nail gun. If not get the battery charged and/or replaced as needed.
Third make sure all of the safeties are working properly and that you have them engaged to the piece of wood you are nailing when you try the trigger.
If beyond that it does not work it could be a bad trigger, a bad safety switch, or even a bad connection from the battery to the device.
Nov 01, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
I have a Polaris 300 4x4 and the front axle will not engage when you push the button. The "AWD" light comes on, but front tires will not pull. Any thoughts?
I have the same atv.it has a "demand 4" awd.Which means the rear tires have to spin without traction before the front wheels will engage.A good way to test it is lift the rear end up on a block of wood to suspend the tires.Put it in awd mode and gas it.The front tires should pull the atv off the wood.
Aug 17, 2009 | Polaris ATV
I shot six mails and the frame nailer gun stopped working (could no longer dispense nails) I have a frame impulse cordless; the fan engages upon tip compression, I pull the trigger, the framer does not...
First, make sure you gas is not expired, it has a date on it. Take off the back cover with the allen wrench and two phillips head screws on the sides. Pull it out, being very careful and make sure when you put it back the wires are tucked in there place again. There is an o-ring under the fan that may need replacing causing the vacuum to not work.Also, make sure the little spark plug is clean of all carbon residue. Clean with some WD40 or ether. Worst case scenario fan motor or spark plug. You can find parts for these things. Lemme know. Please rate me
Jun 13, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Tools & Hardware - Others Logo
41 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
