Question about Lexmark Office Equipment & Supplies
Printer will not connect to toshiba laptop after uninstalling software and then re-installing nothing shows up under the Printer folder in Control Panel
    Sergeant:
  • 276 Answers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Posted on Nov 19, 2008
  • smarttech Nov 19, 2008
    Drivers, Software, lost C.D....come this way!
    If you have lost you cd or don't know how to install your printer then all you
    need to do is download the drivers and software from the manufactures website
    that suits your operating system and printer.
    Drivers and software download areas for brands listed below, just click to gain
    access and then locate driver for your needs.
    Brother Epson Sharp
    Canon Lexmark
    OKI Dell HP Kyocera Samsung Konica/Minolta
    Xerox Panasonic
    PLEASE NOTE
    When installing drivers/software it is generally a good practice to -
    Delete
    old/previous installs
    Leave printers USB cable
    disconnected from computer until newly installed software requests it to be
    connected.
I am getting an error message saying Incorrect port detected. The printer is designed to work with USB cables only. The current software setting is not set to USB port. In my printer properties dialog
Do you hear the connect/disconnect sounds when you plug the USB cable into your computer? If you do not, then the system is not recognizing the printer USB port.
Here is what I would do:
1. In the Devices and Printers section of the control panel, right-click on the printer icon, and select printer properties, then select the Ports Tab. Delete any ports connections for the printer. There could be several for the same printer.
2. Uninstall all Lexmark drivers.
3. Make sure that the printer does not show up in the Devices and printers under control panel. If the printer still shows up, remove the device by right-clicking on the icon, and select Remove device.
4. Reboot the computer.
5. Re-install the printer software. The software should detect the printer on the USB port.
Good luck.
Alex
Feb 14, 2015 | Lexmark X5650es All-In-One Inkjet Printer...
Had to install a new harddrive on my HP computer, while installing the HP J4580 software I had a power failure.....rebooted and uninstalled (using the control panel uninstall) the J4580 software. NOW when...
it's sure that the hp j4580 entries are still existing in the computer if the installation was done with the cd-rom then please do the following steps: insert the cd-rom into the computer do not auto-run the cd go to the hp cd icon in my computer right click on cd icon then click on open then look for folder named util under util right click and open folder ccc then under ccc you will look for a file l3 uninstall or uninstall.l3 right click on it and click on open then disconnect the usb cable from the printer(in case it is a wired installation) go on selecting the files that the uninstaller will show then do not restart then go to the control panel go to add or remove programs remove the hp softwares if exists(hp j4580 required software,hp solution centre,hp imaging device,hp customer participation program,shop for hp supplies,etc.. ) then go the start icon go to the run option enter "regedit" then registry opens up click on h-key local machine select software then select hp printer entires that are highlighted then delete them from the registry restart the computer then download the fresh version of j4580 from hp.com then install the software the issue will be resolved for a software download install: go to the folder where the downloaded version is saved then right click on the software and click on `run then close the folder then go the temp folder by writing the command in the run box %temp% then look for a folder that starts with the name"7z........." open that folder then look for util folder then the steps mentioned above will be done please try this and the issue will be resolved if the issue remains unresolved please revert back
Dec 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
I have a 2 1/2 yr. old Toshiba lap top with operating system: VISTA. It is connected to an HP C6280 all in one printer. I cannot get the printer to print and what I am seeing is that my printer is...
Hi Ed,
HP Printer/Vista conflicts are legendary. Epics will be written about them. :) It's highly likely that an HP Update fouled Vista, or a Vista Update fouled HP.
The surest way to get your printer back is:
1. Go to HP Support and download the Full Software for your model printer and save it to the desktop.
2. Uninstall every HP application in the Control Panel that came with the printer, starting with the main printer software itself.
3. Hold down the Wndows Logo button on your keyboard and press the R key. A command window will open. Type in %TEMP% and hit the enter key. Your Temp File folder will appear. Delete EVERYTHING in the Temp Folder that Vista will let you delete.
4. Reboot your computer.
5. Double click on the HP Software install .exe file you downloaded to your desktop. Install the printer again as if it was the first time.
You should be good to go.
Be well.
TheSelkie
Jul 18, 2010 | Toshiba Computers & Internet
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
6310 interface with latop with vista
is it scanning from the standalone machine ?
if yes .. then uninstall the driver using the disk ?
Explore the Software CD Contents and look for "uninstall L4" (which will be located under a yellow folder named CCC)..and double left click on the "uninstall L4" icon...
make sure u unplug the printer from the computer before u run the uninstaller..
once the software is uninstalled ..reboot the system and install again..
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Can not install on my laptop
If you are having problem to install the printer, or get your printer on, do the following:
Check all connections first if necesary replace the cables and try again.
Be sure the printer is ON
Go to Printers Folder (Start >> Control Panel >> Printers) And be sure your printer status is marked as "READY"
If not, Uninstall the printer and install the printer again but
During the printer installation follow the software steps
to remove your software go to >> Start >> Control panel >> Add/remove programs
If you did it already and your software is still in your computer do this:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation. (Usually in folder "Program Files")
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
If you dont have the CD:
To get your software go to: www.canon.com
Support >> Sotware and drivers
And download there your printer software
Have a great day!
Pablo :-)
Oct 18, 2008 | Canon Office Equipment & Supplies
Installationcompletedprinternotprinting
If not, Uninstall the printer and install the printer again (*A) but
(*A)
This will fix your problem.
Thank you for using FIXYA!
Cheers!
Pablo
Oct 10, 2008 | HP Office Equipment & Supplies
HP Photosmart C7280 All -In_one---can't get it to scan
1. Tried opening HP Solution Center
2. Try scanning using the solution center
3. If you still unable to scan using the HP Solution Center try to check if there is Digital Imaging Monitor in the lower part of your screen. If you can not see it download the scan diagnostic utility.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-45265-1&jumpid=reg_R1002_USEN
Note : do not save the software. Just run it. If it still unable to solve your problem.
4. Click on start and go to control panel. Under control panel go to scanners and cameras. Try testing the scanners and cameras. If it works try restarting your computer and then try to scan.
5. Try to scan using a shorcut from the hp software. Right click on MyComputer and open it. Open C drive and go to ProgramFiles. go to HP and then go to bin folder. Under bin folder look for hpqscnvw.exe and try scanning using the software. If you are satisfied using the program you can put a shorcut of it in your desktop. If you are unable to scan using that program.
6. Uninstall the software using the CD. Do not use the uninstall button on the cd software. Once the installation screen would come up just click on exit. Open MyComputer and then explore the CD software. Under the CD look for the "util" folder and under it look for "CCC" folder. If you are connecting the printer using a usb cable unplug it. Then uninstall the software using the Uninstall l1, l2, l3 and l4. After uninstallation put a check mark on restart later and click ok.
7. Close all the programs you have open.
8. Click on start and then Contro Panel. Go to Add/Remove Programs. If there is an entry for the printer software uninstall it. After uninstalling it close the programs being opened.
9. Click on start and then Control Panel. Go to printers. If there is an icon for the printer delete it. Right click anywhere in the printer folder screen and then select server properties. Click on port tab. If you see their a port for your printer delete it. Click on the driver tab. If you see their a driver for the printer delete it.
10. Close all the programs.
11. Remove registry entries for the printer
11a. click on start and then click on run. Type in there regedit.
11b. create a back up registry by right clicking on computer and select export. The file name for the backup registry should be HPBackUp and save it on your desktop.
11c. After creating a backup registry. Delete printer entries. Click on the computer. Then Press and hold CTRL button and then f. A new window would open up. Make sure that in that window only the first and last option have a check mark. On the search box type in their printers. and then press enter. It will search for printer folder and under printer folder if you see there an entry for the printer delete it. Keep searching "printers" folders until you have completely remove the entry for the printer.
12. Download the software of your printer in the website. www.hp.com/support
13. Install the software again
14. Try scanning afterwards using the HP Solution Center
Aug 10, 2008 | Office Equipment & Supplies
Can't find toolbox for printer
i have a canon 4150 mfp printer
but it is not working  under the linux base ubuntu os
the manuf not supplied the driver
give us solution
vasukon@gmail.com
Jul 15, 2008 | Office Equipment & Supplies
Error 0x0000002when trying to install hp photosmartC5100[printer C5180] all in one printer to a toshiba laptop with vista
Seems like its a common problem.
Are you using a usb cable direct connection or a serial to usb
based in microsoft's forum
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=2298899&SiteID=17
Try this:
1. Make sure the only printer connected is your hp printer that you are having problems
2. From your control panel go to system then go to device manager
3. Under universal serial bus controllers, look for usb printer or any usb printing device you see there and uninstall it.
4. Disconnect your usb cable from the printer and your computer
5. Uninstall the driver from the add/remove programs or hp's driver software uninstaller
6. Restart your computer
7. Download the latest driver from hp's website or use the cd installer
8. Plug in the usb cable from both ends and restart again the computer
Jun 13, 2008 | HP Office Equipment & Supplies
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
