Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Xbox 360 no video no audio no red lights
By snakexxjenki on Nov 19, 2008
hello, my xbox 360 appears to have a bad video card.  it started with the screen turning different shades of colors while playing games, such as GTA4.  After about two weeks, the 360 would turn on fine, and read the controllers, but no audio/video would appear.  it is NOT the TV, and NOT the cords.  i believe the GPU is blown, but am certainly not an expert.  it is past warranty so i pried it open, removed every single piece up to the motherboard, and can not see a visible malfunction. PLEASE PLEASE PLEASE help me out!    i was wondering what i could possibly do myself, or if i truly do have to send it into a computer repair shop.
Comments:
Nov 20, 2008
- so your saying my cpu or gpu overheated?
Nov 22, 2008
- should i remove the thermal glue holding the gpu and cpu down also?  i have cleaned them off, but since i havent found the 'arctic 5' the xbox overheats and shuts off before anything appears on the screen.
Same Problem
Mar 31, 2009
-   I have No audio or video from my xbox thought it was my AV cables turned out it was not after buying a new one. Must be TV then? no definately not.
Xbox is definately working cause i can connect controllers i managed to open the cd drive using the controller with no screen.
Just no GFX or Audio a right pain in the arse. !
Please help! -   skyknight_cs
Mar 17, 2009
-   hello i have a xbox 360 that have no sound at all i try and try the audito to the sound box on the xbox 360-   Guest
Feb 21, 2009
-   the 360 played fine up to a certain point until it began playing with malformed colors showing primarily purple and green. it happened when i was playing Gears of War 2 and when i went to examine the cords and tv it seemed fine-   Guest
Nov 19, 2008
-   My Xbox 360 elite went out after i started playing gta4 the screen turned green and than i turned it off and back on and the red ring of death came on but i took it apart and put the washers and new bolts on the heat sinks but now i dont have the rrod but there is no audio/video at all so i was wondering if the video card went out and if so is this possible to get repaired at a computer shop or tv electronic shop. -   bambamnwk
Best Solution
posted on Nov 20, 2008
Helpful)
da0ne
Rank: Apprentice
Rating: 95%, 13 votes
same here i finally got it working though. U need to clean off the cpu and gpu then add some arctic 5 .after boot it up block the vents with a towel and leave it for 5 minutes then turn it off .if it got hot enough it will set the video card solder back in place .i recomend pushing down on the two heatsinks while its cooling down .after that leave it off to cool right down then turn it on while holding y and the righ trigger until it reboots.thats what fixed my video u might have to try a few time before it works depending on how hot it got.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 24, 2008
Very Helpful)
da0ne
Rank: Apprentice
thats because the chips are over heating they need to be on the heat sinks tighter remove the x clamps look up x clamp fix on your tube that fixed my problem
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
how do i get halo 3 to work because it keeps saying player faild to load content on campaign mode
Answer
How do I remove the ethernet connection from the motherboard. What do I replace it with?I have it... (More)
Answer
how can we save a game to the external memory chip
Answer
some games dont load i get a back screen and the guide wont even come up when i press the button
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
