Question about Nikon Coolpix 5900 Digital Camera
Helpp! exceeded the power limits on its hub port?
My camera works fine, but then when i plug the camera in with the USB cord, it says power surge on hub port, the device has exceeded the power limits on its hub port. click here for help.. so i click and it comes up with a screen that says disconnect your camera and press reset. when i do, nothing happens.
  • 2 more comments
  • William mobley Dec 02, 2007
    I have precisely the same problem described above, and I googled the problem and was directed to this site for a solution. I have the Panasonic Lumix DMC LZ1 digital camera.
  • Tony888a Feb 10, 2008
    I tried that - didn't work. I even tried reinstalling the usb ports - didn't work. I heard the one about disabling the balloon message, but I also heard that all that happens is they run in the background and slow the machine down. No One seems to know WHY its happening, though - and that's a worry....
  • bloux2006 Feb 09, 2009
    usp port is full
  • eps2son Apr 27, 2009
    I have the same problem. I have a canon power shot camera that I have been using with the same ports for 3 years and all of a sudden I starting getting this message
    Power Surge on Hub Port"
    A USB device has malfunctioned and exceeded the power limits of its hub port.
    I have tried all of the suggestion with no luck as of yet.
    I have tried plugging it into other computers and I get the same message on the other computers.
    All computers was working fine until 3 days ago now none will accept the camera.
    Any more suggestion out there?
    Thank's in advance for any help
A simple solution is buy a powered usb hub ( which has an adapter which plugs into the mains) that should solve your problem
Posted on Sep 30, 2007
Shut down the computer, unplug the power cable and wait 10 seconds. Connect the power cable and start the computer. That would reset the power on the hub port.
Posted on Jan 30, 2008
A USB device has exceeded the power limits of its hub port
Windows display this message when a USB device is short-circuited. Try another USB cord or connect the usb to the port at the back of your pc. If it does not help then the problem resides in the printer. I will not suggest to dismantle your printer as there are no user serviceable parts inside.
Aug 10, 2009 | Canon LaserBase MF5650 All-In-One Printer
Power Surge On Hub Port
try to test the camera on another pc..There is 2 probability here, either it is faulty or else there is something wrong with your usb connection...
Jun 16, 2009 | Logitech QuickCam Pro Webcam
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Usb power surge
The Safely Remove Hardware icon list all removeable devices regardless whether it is a USB or PCMCIA or a removeable CD/DVD drive etc.
To get around the problem with your USB device that exceeds the power limit of the computer's USB port. Get a powered USB hub and connect it to the computer's USB port and plug the USB device into the powered USB hub.
Apr 06, 2009 | IBM ThinkPad T30 2366 Notebook
try to change a new USB cord, and if it does not work the problem is a device then
Jun 21, 2008 | Vivitar MAGNACAM Binocular
Camera won't let me upload!
try useing it on another computer you dont have to install sony software to use the camera on another computer if it dose work that tells you that its prob your USB port.
Feb 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
May 15, 2007 | HP Deskjet 5440 InkJet Photo Printer
Nikon Coolpix 5900 Digital Camera Logo
3,072 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
