Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer will not start
You hear hummmmm and smell the motor burning. How much does a motor cost?
    Problem Solver:
  • 6 Answers
Motor won't start. The reset button won'the push is and reset. I can push it in, but it's really loose and isn'the working right. Have I blown the motor?
More likely that it is a bad door switch. Push the door switch in manually and see if you can hear/feel a clicking sound. If this switch is not made (closed) the dryer motor will not start. If you burned up your dryer motor (unlikely) you would have smelled those burned motor windings! Hopefully as simple as replacing the door switch.
Feb 13, 2017 | Dryers
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
Dryer won't start-Get a buzzing sound when pressing Start
Sounds like motor cost any where from $100 to $150
maybe a little cheaper if find the right place
Apr 24, 2010 | Dryers
Dryer does not tumble -had a burning smell - just clicking when I hit start
The motor has gone bad on your dryer...
The burning smell was the motor burning up..
You will need to replace the motor...
Here is a tip I wrote about your problem....
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 28, 2010 | Frigidaire Electric Dryer
Making buzzing sound and not turning. then the buzzing sound stops and it smells like something is burning. then u will hear a clicking noise and sound will stop all together and nothing will happen unless...
The motor on your dryer has gone bad. The humming is the motor trying to start and the smell is the motor getting hot because it is not starting.
You need to replace the motor.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 09, 2010 | Kenmore Dryers
Put clothes in, set the timer, push the start button and it makes a hum like it is trying to start but does not start and then there is a funny smell coming from the dryer. Is the motor burning/burned up...
it could be the belt slipping,the motor going bad, the motor start cap going out the drum bearing or motor bearings dried out causing over heating of unit causing electrical smell, hard to give a ball-park,anywhere from $50 to $300 for repairs depending parts required and labor/time
Oct 28, 2009 | Amana DLE330RAW Electric Dryer
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Will not turn on..
Hi trishis26,
If it was the motor you would still be able to hear it trying to start. The will make a loud hummmmm. Since it is doing nothing you most likely have a bad thermal fuse.
Other possible problems include the door switch, the start switch, the timer, the breaker in your home. If you need more help, just let me know and I will be happy to try to help you figure it out. Good luck.
Mike
Sep 29, 2008 | GE DBSR453EBWW Electric Dryer
Lady Kenmore electric dryer broken start button
it is time to replace it, that sound and smell is from the dryer motor itself.
Jun 28, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
105 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
