Change the time on an RCA AcuSearch 4 head VCR
Just need to know how to change the time
Benimur
  • 6966 Answers
SOURCE: Internally change channel 3 to 4 on VCR
Hi, In most VCRs, as you have posted, there is a switch at the back where you can select the output to either Ch 3 or 4. In some cases, the switch is deep inside and you have to remove a small squarish rubber covering to expose the hole. It is normally close to the antenna input/output. More often than not it is a simple sliding 2 position switch. You would need any tool that can reach and sturdy enough to slide the switch. Internally program output channel selector is very possible, I would guess that its selectable via the menu set-up tabs. A question pls, How did you "I tried to manually change the channel to 4, but the VCR reverted back to channel 3..." Hope this be of some help to you. Pls post again how things turn up or further information. Good luck and kind regards.
Posted on Aug 02, 2007
SOURCE: quasar omnivision 4 head clcok
You do not need the remote - you can access the menu manually.
  1. Take out (eject) the tape;
  2. press the 2 Channel buttons ("up" and "down") simultaneously;
  3. follow the menu as easily as you did when you did have the remote and you can change all the clock settings;
  4. press the FF button for >, the REW button for <, the PLAY button for UP and the STOP button for DOWN.
  5. when finished, exit the menu with the simultaneous pressing of the Channel UP & DOWN buttons.
Posted on Nov 02, 2008
  • 4 Answers
SOURCE: No video on VHS tapes playback. on a Zenith VR4257HF
Sounds like the video heads are worn and time to replace them. You can try Asti Magnetics. The part number you are looking for is "378". Sells for $55 plus shipping. A bit cheaper but quality parts. I've dealt with them in the past. You can decide if the VCR is worth it to repair.
Posted on May 04, 2009
Grubhead
  • 5309 Answers
SOURCE: Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
Posted on Mar 10, 2010
  • 417 Answers
SOURCE: need to know how to change recieving channel on
There should be a switch on the back of the unit.
Posted on Apr 15, 2010
VCR immediately ejects tape or draws it in and starts to eat it.
All pinch rollers and heads need to be cleaned! They probably got sticky from not being used.
Jan 17, 2014 | RCA Hitachi Vt-fx665a 4-head Hi-fi Vcr...
The VCR is playing and functioning, but the picture won't show up on the TV. I have all the channels set and it should be working, but the TV is the black and white static. Could it need dusted? It hasn't...
make sure the tv vcr button on the vcr is selected to vcr and that you have the tv on channel 3 or 4. try pushing the tv vcr button a few times back and forth on channel 3 then on 4. if that doesnt work try hooking the vcr up to the tv with the rca jacks. they will be yellow, white and red or maybe only two from the vcr yellow and white. hook them up the the correct input on the tv and change the input on the tv. if that doesnt work, your vcr may be done.
Dec 24, 2010 | RCA VR557 VHS VCR
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
May 16, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
May 02, 2009 | Zenith VR4257HF VCR
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
How to set the time
Have you tried using the set up menu button on your remote? nanafromlv
Nov 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
TV/VCR combo
Try clean the AC head with a
foam type head cleaning Q-tip
when you take the cover off
tle AC head is the device
to the R of the drum that
resembles a recordling head
because thats what it is
clean the dark strip up
uner the littl ridge at the
top
Nov 22, 2007 | RCA T13208 13 in. TV/VCR Combo
Change recording speed
The only solution to this problem is to buy a new remote from the manufacturer. Aftermarket remotes that I have looked at: RCA, PHILLIPS, SONY, etc do not have a speed select button for the VCR. (which IMHO is stupid) Come on aftermarket people- it cant be that hard to program a speed select button!
Oct 13, 2007 | Emerson EWV603 VHS VCR
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
