Question about Stainless Compact Steel Refrigerator - 1.7 Cubic Foot
Chemical stains on the stainless steel fridge
My kid sprayed the Easy Off on my stainless steel refrigerator and now i have all these chemical stains on my fridge. can you please help with any possible solution to this BIG problem. it's a fairly new fridge and i can't afford to buy another fridge too soon. any help in this regard is greatly appreciated.
thanks
  • 30 Answers
If the damage is shallow, you can scrub off the top layer with Bar Keeper's Friend and damp sponge. (Don't worry - it only takes off a micro-layer). Rinse and dry. If the damage is gone, wipe with mineral oil. If it's still there, I would try a few more times before giving up.
Posted on Sep 30, 2009
    Scholar:
  • 145 Answers
Dilute oxalic acid and scrub gently or firmer till you are comfortable with matching the grain. Use a scotchbrite sponge pad- break it in on your stainless steel sink practicing going with the grain. Water rinse and rub will nutralize acid.
Finish and maintain with DeBruce Polish- THIS STUFF IS THE BEST, and once the whole unit is completely cleaned all you will every have to do is touch up the spotting areas, reclean whole unit yearly or as ofton as you like. We find DeBruce Polish online at debrucepolish.com.
Posted on Jul 27, 2009
  • Bruce
    Bruce Aug 24, 2009
    Start with DeBruce Polish first- it should do the job
  • 91 Answers
Buy a stainless cleaner nd polish it should remove the marks, dont forget to polish in the same diarection with the grain of the steel
Posted on Aug 31, 2009
  • gav Sep 01, 2009
    if you use any scotchbrite on the fridge to clean out the mark you will end up having to do the whole front of the fridge as nothing can blend in a factory sheen/grain finish.ive been welding and polishing st/st for 14 years
5 Suggested Answers
SOURCE: dent in easy clean stainless
first off its not "stainless" its clean steal. and yes it does dent very easy! i found the only answer is to replace the panel or buy a new fridge .. i do NOT recommend clean steal to anyone. i have the same problem a very expensive fridge and i already have many dents in it also scratches. the lady "highly recommened this fridge for people who had kids" i guess i should have done my H.W
Posted on May 20, 2009
SOURCE: discolorations/stains on stainless steel refrigerator surface
Tried lots of suggestions to no avail. Tried a USED, dried out Scotch Brite Cook Top pad on the scrubber handle with Heavy Duty Fantastick sprayed on the pad. Scrubbed the drip marks at the bottom and wiped away to see if it was "scratching" or marri8ng the finish. Nope, but IT WAS taking the water marks off. So I did a bit more and checked again. Working great with no problems for the finish. Cleaned the whole watermark area. Rinsed of with wet cloth. Let it dry and then used my usual stainless cleaner, buffed to shine and walked away to post this. :> My refrig is an Aman too but I read other problem sites and it is common with stainless steel refrigs
Posted on Aug 08, 2009
DeBruce
  • 145 Answers
SOURCE: Dent in stainless steel refrigerator door
Find and auto body that performes the paintless dent repair
Posted on Aug 24, 2009
DeBruce
  • 145 Answers
SOURCE: stain (drip mark) on front of fridge???
We Use Debruce Polish in all our kitchens, especially cooktops and stainless steel. Debruce also works on polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff is perfect!
Please tell me how to get water stains off the front a stainless steel fridge. I have tried everything I can think of.
James, If really stubborn stains, you may have to use a chrome polish and buff. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cleaning Stainless Steel Appliances Cookware and More
Removing stains from stainless steel refrigerator
How to Clean Stainless Steel Appliances Easy Kitchen Cleaning Ideas That...
Coulter Cleanup Refrigerator Rejuvenation
Jun 11, 2016 | GE Profile PFS22 33" Artica French Door...
How to clean stubborn burned on stains in the stainless steel oven
You need to use ordinary soap as a lubricant and a fine steel wool to buff the steel surface. That will remove any built up surface debris completely but you may still have some discolouration of the metal remain.
An automotive polish designed for polishing stainless steel and aluminium (available from auto parts stores) might finish the job for you and remove much of any remaining staining but I would not use a chemical of that type on an inside surface that is used for cooking your food. (Same issue with those dreadful chemical and toxic oven cleaners).
Unfortunately, with use of the unit and heat , you will get some residual discolouration of the stainless steel.
Nov 11, 2015 | Stainless Kitchen Ranges
If my Kitchen Aid KSF26C6XYY00 door is in fact made of stainless steel, why do fridge magnets stick to it? Ohter people I know that have stainless steel fridges say that the magnets do not stick to t
Stainless steel is a term for a family of high chromium steels, some of which do in fact stain, although they do not rust as ordinary steel does.
The more expensive 'austenitic' stainless is non-magnetic, but harder to work into product shapes. 'Martensitic' stainless is a little more prone to staining and corrosion, but easier to work with, and is magnetic. Then 'ferritic' stainless is even cheaper, but less corrosion proof, and is also magnetic.
So yes, many stainless steels are magnetic, and if the manufacturer has not used the very most corrosion proof but expensive grade, then you will see it in that way. I would not see much reason for a fridge door to be made from austenitic stainless.
Feb 17, 2012 | KitchenAid KSF26C6Xyy Side by Side...
How to clean maytag stainless steel finish on appliances
HOW TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do not use abrasive or harsh cleaners such as window sprays, scouring cleansers, flammable fluids, cleaning waxes, concentrated detergents, bleaches or cleansers containing petroleum products on plastic parts, interior and door liners, or gaskets. Do not use paper towels, scouring pads, or other harsh cleaning tools.
How do I clean and care my stainless steel surfaces such as refrigerator or any other stainless steel made appliance?
NOTE: Just because a cleaner is a liquid does not mean that it is nonabrasive. Many liquid cleaners designed to be gentle on tile and smooth surfaces still damage stainless steel.
> Avoid Citric acid
-it can discolors stainless steel. To avoid damage to the finish of your stainless steel appliance, do not allow these substances to remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If you want to clean safe and keep the sparkling steel you can purchase STAINLESS STEEL WIPES this wipes is ideal for cleaning food spills,grime and stains leaving surfaces shining like new. This wipes is for stainless parts only make it sure this stainless steel wipes to come into contact with any plastic parts.BUT THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH CLEAN WHITE CLOTH.
Jan 26, 2011 | Maytag Refrigerators
Stains
stainless steel polish will do this don't get too abrasive a cleaner though,there are different coarsnesses of the product
May 15, 2010 | Jenn-Air JCD2389G Side by Side...
Zap damage to stainless steel
You should try a citrus based stainless steel cleaning agent, this should take off the stain. Otherwise you can do a test on a concealed spot, stain it with Zap and then lightly brush over in straight lines with medium sandpaper in same direction as original. But try it on a concealed area first.
Mar 23, 2009 | Refrigerators
Fingerprint stains on stainless steel fridge doors
going with the grain( s/s has grain just like wood product) try cleaning with a stainles steel cleanlingcloth and some wd40, this will remove any defect in th metal go with the grain not across you will leave rub marks if going avcross t he grain!!
Feb 12, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Stain (drip mark) on front of fridge???
Jun 06, 2008 | Stainless Compact Steel Refrigerator - 1.7...
Dent in easy clean stainless steel fridge door
Apr 28, 2008 | Refrigerators
Stains from cleaning products?
Bosch (BSH appliance care) do a stainless steel conditioner you could try. I think its called Starglanz.
Nov 05, 2007 | Bosch 36 in. NGT 935 Gas Cooktop
Stainless Compact Steel Refrigerator - 1.7 Cubic Foot Logo
2,398 people viewed this question
Top Stainless Refrigerators Experts
Dan Webster
Dan Webster
billconfused
Are you a Stainless Refrigerator Expert? Answer questions, earn points and help others
