Question about Hitachi DV-PF33U DVD Player/VCR
Hitachi DV-PF33U DVD Player / VCR Combo
When trying to play a VHS tape the tape will play for a few seconds then stops. The display then shows " Err 1 ". Thank you
  • Anonymous Feb 23, 2008
    Same problem, plays for a few seconds and then gets error 1. Can you tell me where the sensor is located that tells the micro-processor that the tape is moving? Also DVD code is at 1.00
  • Anonymous Mar 21, 2014
    My RCA drc8295 VCR/DVD combo wont play my tapes
    Sergeant:
  • 308 Answers
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
SOURCE:
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Want to copy vhs to dvd.
I convert VHS to DVD using a Toshiba DVD Recorder that I purchased from Costco a few years back. I plug the VCR into the DVD recorder using RCA jacks, press PLAY on the VCR and REC on the DVD recorder and let it sit and record. I can record up to 8 hours of video onto one DVD at low quality. After this, I finalize the DVD so it can be read on other DVD players.
Jan 03, 2012 | Hitachi DV-PF33U DVD Player/VCR
VCS422. The VHS will play with a tape, but not from the TV. The display just as four horizontal dashes. Thanks.
I would suggest you replace your AV cables.
After a few years the cables can go bad.
If this doesn't fix the issue, try playing the tape in another VCR.
If that works, it's probably time to replace your VCR with a VCR/DVD combo player.
Mar 13, 2011 | Zenith VCS442 VHS VCR
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
The vhs tape will not eject or play it keeps reading Err.
the sensor that tells the VCR there is a tape in the player is bad or might need alined! (may cost more to fix then a new one!
Dec 08, 2008 | Daewoo DV-6T955B DVD Player/VCR
DVD-V3500 DVD player works fine the VHS does not display
Its problem of dirty / clogged video heads and can be solve by using VHS video head cleaning cassette.
Regards,
Sep 14, 2008 | Samsung DVD-V3500 DVD Player/VCR
Dvd/Vcr combo
often if you turn off machine, then hold eject as you turn machine on tape will come out.
Feb 13, 2008 | Sanyo DVW-7200 DVD/VCR
Error 2
my vhs/dvd combo sylvania shows error 2 how do i fix this
Nov 15, 2007 | Sylvania SRD3900 DVD Player/VCR
Hitachi DV-PF33U DVD Player/VCR Logo
367 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
