Question about Dell Inspiron 1300 Notebook
Desktop on my desktop i have two white squares which i cannot get rid off, although my screen is fine and computer working well these two white screen remain. cannot right click and delete and have tryed system restore but too no avail.there is no cross to close down and have gone into control panel and tried from that side. if i go into safemode the squares are gone.
  • jackie davies Dec 14, 2006
    thank you for getting back so fast, but went into my computer to remove the graphic card and there is no icon saying graphic card went into the help section and put in to remove g,c but nothing came up to help not sure if it would be under anything else. so i still have the same problem.(sorry not that clued up on the in's and out's of my pc)
    many thanks
    President:
  • 2,961 Answers
If the squares are gone in safe mode it's safe bet that it's your graphics card driver. Uninstall drivers in add/remove programmes and re-boot your pc and see if the correct driver is re-installed. If at all possible it's best to use the driver from your notebook's manufacturer web site.
Posted on Dec 11, 2006
SOURCE:
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
I have black and white lines running down the screen after I connected it to internet. How do I get rid?
Could be a lose cable, Check the cables connecting to the monitor (screen) and the to PC.
Also, made sure your phone or any other electronic device(s) aren't in close proximity to the screen. They sometimes cause interference.
Jan 07, 2013 | ASUS Computers & Internet
Had a virus got rid off it but now screen is white and cannot do anything with it
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
My computer screen has a big white box over the desktop icons How can I fix it.please ?????
is the white square on the desktop or floating as a separate window? Can you use your PC and programmes OK, but it just looks rubbish?
If the latter I suspect that there is some sort of custom desktop which has been corrupted.
To change it right click anywhere on the desktop and choose properties. The choose desktop and swap the current one from anything on the list. Save and the background will change. If it is as I suspect the white square will also have vanished.
Sep 11, 2010 | Computers & Internet
When I boot up my computer and get to the Desktop, a black 4 inch square appears in the center of the screen. Clicking on Internet Explorer makes it go away. How can I get rid of it? Glenn Tansley
is it a blank black 4 inch screen? can you boot your computer and when you see it press print screen on your keyboard and open up your paint program and press ctrl + v and save the picture and post it here.
Jul 11, 2010 | Dell Computers & Internet
Will not go past desktop screen, display turns white
Try this first
just hold in the home button(the one with the square) and the top button at the same time untill goes black then conect to itunes or computer should go back to normal
If this doesn't work then
Install latest video drivers. if onboard video, try installing latest chipset drivers.
(ftb)
Nov 21, 2009 | Acer Computers & Internet
Big white square
Dear,
Remove all the startup item from your machine and try. How to do it... http://teamtutorials.com/windows-tutorials/remove-items-from-windows-xp-startup Install a good antivirus and scan the machine in safemode and see.. how to boo in safemode http://www.pchell.com/support/safemode.shtml
Oct 17, 2009 | Dell Inspiron 530s Desktop Computer
Black and white screen
I had the same monitor and same problem. Nothing you can about it if your computer works fine... than its not your computer's falt. I got a new monitor. That's the best you can do too mate! :)
Aug 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Out of Range
the refresh rate of your computers graphics card is set either too high, or too low. right click on the desktop, select properties, go to the settings tab, and click advanced. then go to the Monito tab, and play around with the different refresh rates, until the picture will show up. This is usually, around 60 Hz or less.
Feb 10, 2008 | Philips Magnavox 27MS343S 27" TV
Dell Inspiron 1300 Notebook Logo
115 people viewed this question
Clive
Clive
Alun Cox
