Question about Fuji FinePix A400 Digital Camera
Help please my lense is sort of stuck ,and in the menu screen ¨focus error¨ pops out
    Sergeant:
  • 420 Answers
Try these:- connect it to pc and on it vaccum the barrel of lens changing mem. card and batt. for 2min.
Posted on Sep 11, 2010
Machine clicks when turned on and focus is stuck. it sounds like focus gears aren't meshing properly
hi, Zoom/Focus Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
hope this helps
cheers
May 05, 2011 | Cameras
Lens adjust is sticking. With the lense out you
since you have then lens out, get a wide blade flathead and insert it in the smallest part if **** that it will fit into behind the focus ring and turn the blade like you are trying to widen the **** all the way around until it pops out into it's normal position. Getting the entire lens back in properly is a bit tricky since the threads are easily stripped. First screw it all the way back on and then check the focus on the screen. You want to see a crisp image in 3 if not 4 of the outer corners of the screen. It is best to use something with text that fills the whole screen so you can see the 4 corners as you adjust the focus. If the focus is good in the corners, leave it alone. If not,hold the back of the projector in one hand and forcefully push the lens into where you screwed it on and see if it pops into place. It really is trial and error. Once you have a clear picture it is a good idea to remove the top cover and glue all around the base of the tube where it screws on so it doesn't come loose again.
Jul 30, 2010 | InFocus LP70+ Multimedia Projector
Lens stopped working after holding lens when on auto focus
error 99 may be the only error that the camera can identify with the problem. Generally this is dirty contacts in the camera and on the lens. The fix is to rub them with a pencil eraser and ensure no rubber swarf gets inside the camera. ( Hold upside down and use a blower and brush for cameras after doing it. Do the same to the lens contacts and re position turn on camera and see if it works ok now.
Please rate my help++++Thanks for using FIXYA
Jun 30, 2010 | Cameras
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
Feb 23, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Toshiba 50H81 access to lenses
Hi Dan,
I emailed you 2 ideas, how to get approach lenses for focusing.
Hope that would be helpful to you.
Dec 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Hi there i have a auto focus problem. i used mt 50D for the first time on saturday, after about 100 shots Err99 appeared, i turned the camera off and took the battery out an the error message never occured...
The camera is having problems with your lens and this is why it goues into the error mode. Try first cleaning the interface contacts on the lens ( see enclosed pic ) . If this does not sort the problem out then the auto focus motor ( or related hardware ) inside the lens will need attention. Also try other lenses to see whether it is only the lens ( I very seldom see this sort of problem cause by the body ; it is always the lens that gives this sort of trouble )db49ae2.jpg
Nov 04, 2008 | Canon Cameras
Sometime Tv gets stuck on a input or menu. Please HELP!
Unfortunatly the problem sounds like a software error which could only be sorted by an engineer, also your buttons on the front are also controlled by software,and cannot be disabled.
Dec 23, 2006 | Toshiba 32A43 32" TV
Focus trouble
I believe that this is the same question which I answered previously. Here is the answer again - If your unit has a switch for manual focus, put it in manual. If you cannot focus the unit in manual you have a problem with the lense and it will need repaired and/or replaced. If you do not have manual focus you will not be able to troubleshoot the unit. It could be a lense problem as stated before or a problem with the Auto Focus system, perhaps just out of adjustment, or something more serious. Either way if you are not capable of camcorder repair you will have to seek the help of a reputable repair shop. Good luck.
Jun 12, 2006 | Samsung VP-W70U Camcorder
Fuji FinePix A400 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
