Question about Nikon Coolpix S210 Digital Camera
''lens error'' and red and green lines going through the schreen
My camera was working fne when i got up in the morning and it the evening i took it out of my draw and it was telling me "lens error" and the lens would not close so i took out the battery to get it off and put it back in and the lens came back in but then after i tried to take a picture i saw red and green line running through the the display and that only happens in the light but not in the dark and also it records videos perfectly but i try to take a pic and its all messed up please help me find the problem.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Take a look at this tip.
Posted on May 31, 2012
advance
  • 107 Answers
SOURCE: Lens error
The most common cause of this issue on the L3 is an impact which dislodges the focus element in the very front of the lens. The metal platform that the focus system is mounted to is attached with 1 screw and is able to flex slightly under stress. When impacted it flexes and allows the focus drive to become misaligned. The lens still technically works but the camera senses that the focus is jammed and leaves the lens extended so no components will be damaged by retracting. This repair costs $145 at my shop, not an economical repair for this camera. Some parts of the focus element are accessable from the front of the lens. You can remove the metal cover (it is glued down). Generally you will not be able to re-install the lens barrier, but it can be removed without harm to the camera. When you remove the plastic plate which carries the lens barrier you will see a small metal gear, this is the base of the focus drive.
Posted on Jun 16, 2007
jackboy
  • 2985 Answers
SOURCE: my nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Posted on Aug 05, 2007
t00nz
  • 4738 Answers
SOURCE: system error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Listed Fix #4 might work for you. Place the camera on its back, and hold the shutter button down while powering on the camera.
Posted on Dec 23, 2007
  • 188 Answers
SOURCE: Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Posted on Apr 03, 2009
lock123
  • 6831 Answers
SOURCE: nikon d80 will not take pics has err flashing in
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
It worked fine yesterday and now when i try to turn it on it will not power up, and it turned on one time and i turned it off thinking it was ok and now wont go back on
to thirst. control the batterie. if its good. why if the batterie is old its possible that have problems-
if you have new batterie ore 2 or 3 batterie prove with the other.
control that the camera when turned off...dont write on the schreen lens problem, or example the write on the schreen turn camera out and another one up. if the camera dont have received pressure or dropp,
if the camera says lens error this is a problem with the lenns bloc... but to first, prove with a new batterie and clean the internal contact of the camera with alcohol and one cotton fiocc. pull the batterie out clean the internal contact wayth that the alcohol are completly evaporated, and reprove. good luck
Jun 01, 2010 | Polaroid i1237 Digital Camera
The screen won't come on for viewing and the lens won't retrack, it also started popping up with E18
That is shutter error code. I am sorry to tell you have to buy a new camera, it would be to expensive to replace.
Nov 15, 2009 | Canon PowerShot A95 Digital Camera
Camera will not open most of the time,the lens
Your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. It's not a cure-all. but this cleaning cures the problem about 90% of the time. I hope it works for you.
Sep 03, 2009 | Olympus SP-310 Digital Camera
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
Aug 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Error message F-- Nikon D90 w/kit lens 18-105mm
correct - i need to get a good grip on the lens and click it to connect to the body
Jun 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon CoolPix L18 getting lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Mar 29, 2009 | Nikon COOLPIX L18 Digital Camera
I can't turn my camera on????
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error
Lens error means that something happened to the lens, some kind of damage. You need to send it into repairs. Call them at 800-706-2534 option 2 and tell them what error you have and they will tell you where to send it. :)
Jul 11, 2008 | Casio Exilim EX-V7 Digital Camera
LENS ERROR
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jul 11, 2008 | Nikon COOLPIX S200 Digital Camera
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Nikon Coolpix S210 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
