Question about IBM ThinkPad T60 Notebook
Lenovo T60 Touch Pad not working
I bought a T60 without OS over the internet, installed Windows XP, downloaded drivers including ULTRANAV from Lenovo site.
Everything including the Keyboard is working except the Touch Pad.
Thanks in advance for your help
  • 1 more comment
  • disneydoc Nov 19, 2008
    I have downloaded & re downloaded the drivers from the Lenovo site
    Thanks
    No, it was not bought new, no OS came with the Laptop. I loaded a Windows XP, then downloaded the drivers from the lenovo site
    Thanks
    OK, let me try that, this evening. I will reply after that
    Genius:
  • 1,550 Answers
Just check in BIOS set up whether touch pad is disabled .
If it is disabled then change the status and also check in Ultranav in the Control Panel, and check the touchpad box to enable it.
Hop this helps .
Posted on Nov 19, 2008
  • 10,515 Answers
Take off the palm rest and make sure its plugged in?
  • taran_2005
    taran_2005 Nov 19, 2008
    I found that the problem can be due to the palm rest region being pressed down my my palm:
    If I press the palm region up on the edge (as it flex a little bit when I use force), then the touchpad works fine even when the laptop is tilted. However, when I stop pressing up on the edge, especially after I have put my palms onto the palm rest to type again, then the touchpad stop behaving normally again
    ***********************Tak Cre Bro*******************************
  • IBM Master
  • 19,396 Answers
It is the small ribbon canle that connects to the touch pad, it is not well connected or broken.
When the touchpad connector is broken, on many Tinkpads you need to replace the whole upper panel and palm rest, by removing keyboard and upper panel, there is risk to damage the keyboard connector doing this.
Here you find movies on how to disassemble the T60.
You need to chose system dissembly, then movies, then skip movies until you get the touchpad/keyboard removal.
Beat solution is taking the laptop to a repair shop and having the problem fixed.
  • Ginko
    Ginko Nov 19, 2008
    Regarding the drivers, laptop touchpads work even without additional driver, even if with no extra feature.
    When touchpad does not work at all, there is a fault.
    I post my previous comment:
    When
  • Ginko
    Ginko Nov 19, 2008
    Can you see my comment?
    It is not a drivers problem, if it does not work at all is either hardware fault or bios problem.
    If you did not touch bios settings, then it is an hardware fault, nothing to do with drivers.
    Hope you can read this, check my previous comments, and forget about the drivers.
    Genius:
  • 1,913 Answers
Check in device amnger u notmissing any drivers.or any alert on it.
scan your hardware changes.
theninstall from here drivver .
firart remove your current touch pad driver.
http://search.lenovo.com/Search/?q=touchpad+dirver&v=15&lang=en&cc=us
    Brigadier General:
  • 3,614 Answers
I want to know if you bought the items in a brand new conditions.?
do you have the cd driver pack included on the package..
you must install the device driver for the touch pad.
  • IBM Master
  • 1,879 Answers
Visit Lenovo's website to download the TouchPad driver.
  • monk3ybidzness
    monk3ybidzness Nov 19, 2008
    Sorry missed that part that you arleady downloaded the UltraNav :)
    How about this one:
    Verify that the internal TrackPoint or UltraNav is set to Automatic or AutoDisable.
    Note: This setting will automatically disable the TrackPoint and UltraNav if an external PS/2 interface mouse is attached before startup.
    To verify the setting in the BIOS for ThinkPad A, G, R, T, and X series systems
    1. Turn on the computer.
    2. Look for the message in the lower left area of the screen. If it says: "Press F1 for BIOS Setup Utility", press the F1 key. If it says: "To interrupt normal startup, press the blue Access IBM button", press the blue Access IBM button.
    3. Double-click Start setup utility if available.
    For some systems, you may need to click Continue at the Rescue and Recovery Predesktop area screen, and click Access BIOS and Yes.
    The BIOS Setup Utility menu will be displayed. If a password prompt appears, type the correct password.
    4. Select Config and then click Keyboard/Mouse. The setting for the TrackPoint and UltraNav touch pad should be Automatic or AutoDisable.
    To verify the setting in the ThinkPad Configuration utility:
    1. Click Start, select Programs, and look for ThinkPad, Access IBM or ThinkVantage.
    * If ThinkPad is in the list, select ThinkPad, select ThinkPad utilities, and then click ThinkPad Configuration.
    * If Access IBM is in the list, select Access IBM and then click ThinkPad Configuration.
    * If ThinkVantage is in the list, select ThinkVantage and then click ThinkPad Configuration.
    2. Click the TrackPoint icon
    or UltraNav icon.
    3. Select Automatic or AutoDisable.
    4. Verify that the UltraNav and TrackPoint are set appropriately (Enabled or Disabled), by clicking Mouse properties and then the UltraNav or TrackPoint tab.
My scroll key on the right side on the touch pad is not working lenovo g570
One of two things. You may need the utility driver installed, typically the UltraNav Driver. Or you can try switching on the function in the ultranav tab in your mouse properties in the control panel.
Dec 13, 2013 | Lenovo G570 Notebook
Vertical scroll wont work on lenovo g550
Sounds like a driver problem go here: http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=600154
and scroll down to touch pad, and download and install the driver that corresponds to your operating system (windows 7, windows xp etc.)
May 06, 2011 | Lenovo G550-29583AU Notebook
Sounddriver for lenovo t60 ibm thinkpad
I am hoping this site will give you all the drivers you need for the Lenovo including the sound (audio) drivers.
Feb 10, 2011 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
Can't install drivers on Lenovo T 60 after XP Pro reinstall
go to device manager, uninstall network adapter, reboot, windows should find and reload drivers.
Nov 02, 2009 | Lenovo Thinkpad T60 Notebook
My r60 model upper tochpad keys not working
Lets see if the Lenovo computers are alike, since I have a T60 version...
Lets start by going to the: -> START button click on the Control Panel -> click on MOUSE -> click on ULTRANAV tab -> there will be a check mark to Enable the Touch Pad Check off the Touch Pad and click on APPLY to save and OK to back out.
Voila, your Touch pad should be working then.
Good Luck.
Sep 18, 2009 | Lenovo ThinkPad R60 Notebook
How to format and install a OS into the HARD DISK using a PEN DRIVE ......
nope..that is a complete compatibility challenge of the first order..
Oct 13, 2008 | Lenovo Thinkpad T60 Notebook
Lenovo R 61 thinkpad starts with differnt setting each time
Dear,
in now days there is a virus affected your system hardwares so 1st scanned with antivirus than try something new,or try to install your driver again.
THNX
May 15, 2008 | IBM Computers & Internet
IBM ThinkPad T60 Notebook Logo
901 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
