Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
How to fax
How do i fax from the kodak 5500
  • 40 Answers
First you need to get the fax service activated with your phone company. Make sure that you do not have distinctive ringtones nor voice mail activated on your line, because these features are not compatible with the 5500 printer.
Once you got that, then you need to:
- Put what you need to fax on the ADF (automatic document feeder)
- Press the FAX button on the printer
- Dial the number (including area code)
- Press the START button
And your fax should get going.
Posted on Nov 21, 2008
Kodak 5500 aio will recieve faxes but won't send faxes
Make sure that the settings is properly set especially for the region settings. If problem persist please upgrade the firmware of your pinter.
Jan 07, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
My kodak 5500 all in one inkjet printer will send fax, but comes thru blank at the other end. Yes I have the document with lettering up like it says.
The problem, more than likely, is the quality of the scan. The 5500 sometimes overexposes the original. Test the scanner by scanning the document tou want to fax using HomeCenter software and looking at the screen preview. You can make some pre scan image density adjustments by changing the fax settings brightness setting to low (1 or 2) and changing the color setting.
Apr 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5500 Fax won't connect
Most likely problem is your phone company is blocking it for some reason.
Apr 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax pick up
Greetings Nana,
I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fax machine settings for distinctive ring line setup. Kodak 5500
This 5500s don't receive faxes if you have voicemail. You can still send faxes. Just make sure Disable call waiting is set up correctly in Fax Settings
Jul 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to fax when ink cartridge is empty
I talked to Kodak and you can't. You have to have all ink cartridges filled and ready in order to perform any operation! I know, it sucks!
Jun 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak All In One Printer Series 5500
Ok. call 1.800.421.6699 for the print quality prob. With the fax, they might be able to help you too.
Jun 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
66 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
