Question about iLO DVDR05 DVD Recorder
Dish satellite i can not record
When i had directv satellite i was able to record.now i have dish satellite i can setup time recording but when i put the s video it gives no signal.
dish company said to contact your company
    Genius:
  • 1,199 Answers
It sounds like you got a bad reciever or the setting on the meuy of it it wrong!
Posted on Dec 11, 2008
Can I as subscriber to direct tv can I use a mobile satellite dish
DIRECTV FOR TRAVELERS
https://www.directv.com/DTVAPP/content/contentPage.jsp?assetId=P6730097
With DIRECTV's cutting-edge mobile service, you can enjoy your favorite TV ... Contact one of the following distributors to order your mobile satellite receiver and ...
How to SetUp Your DirecTV On the Road in Your RV ' Roadtreking Blog
roadtreking.com/how-to-take-directv-on-road/ Jun 20, 2013 - Learn how easily you can set up DirectTV in your RV. ... You also have a permanently installed satellite dish at your house, probably ... The trick to making your system portable is to bring the box and a second dish on a tripod, ... First, set up your tripod so the mast is perpendicular - use a torpedo level for ...
A Guide to RV Antennas for Satellite Internet & TV - Reviews.org
www.reviews.org/internet-service/rv-satellite-internet-and-tv-antennas/ Getting satellite internet and TV on your RV isn't as hard as you may think. ... DISH and DIRECTV do not actually offer an antenna (dish) that can be used on the ... a proprietary dish for your mobile internet unless you pair DIRECTV with an ...
How to Set Up a Portable DirecTV Satellite Dish ' eBay
www.ebay.com/gds/How-to-Set-Up-a-Portable-DirecTV-Satellite-Dish-/.../g.html Before obtaining a portable DirecTV satellite dish, purchase a subscription. Subscribers who already have DirecTV installed at a residence can use a part-time ...
direct tv can use mobile satellite dish Google Search
Sep 25, 2017 | Televison & Video
Do I need to clear all recordings I have set to remove message 'Can't schedule recording. There is already a timer at the same time on this channel? I have checked library and timers and nor ecording is...
Hi Margret -
(1) You must have available space on the recorder. If it is full, you will need to delete enough programs to provide the room needed for the new recording.
(2) You also need to be subscribing to an entertainment program package that includes the channel that the show appears on.
(3) Depending on the service (Tivo, Directv, Dish, CableTV, etc.) there may be other requirements. The quickest response to get this resolved for you will be contacting the service provider (Tivo, Directv, Dish, CableTV, etc.)
Dec 31, 2014 | Televison & Video
Won't record in HD. DVR shows to be recording, but when you click on the programmed HD channel (the one that's supposedly recording) it's blank and says "searching for satellite". Just started recently.
Have you tried rebooting the DVR and removing the card that came with the DVR if its one that was provided to by one of the satellite company's such as Directv or Dish.
Nov 30, 2009 | Directv HR22 500-Hours HD DVR
Trying to find out what my tvs settings should be on to hook up m
Have you tried channel 3 or the video input channels.
The Tv only needs the one channel that the signal from the box is sent on.
All the viewing channels will be changed through the satellite box.
May 11, 2009 | LG Televison & Video
Error message 771
searching for satellite signal means its not getting a connection between the satellite and the receiver itself. you can check on the back of the receiver where the satellite cables comes in, unplug the satellite cable make sure there is a copper pin sticking striaght up there to make sure its getting a good connection. also if you know where your splitter is, it has a few lines coming in and a few coming out, its somewhere between the dish and the receivers. usually in an attic or basement, or it could be at the dish itself. make sure those lines are tight, no cracks or breaks in the lines. also if your dish is easily accessible check the connections at the dish to make sure none of them have come undone or loose.
Apr 11, 2009 | Directv Plus HDTV Receiver with Integrated...
Can't watch anyother shows while recording another
Check the back of the DVR to make sure BOTH cables from the dish are properly connected to the receiver. Make sure they are properly tightened. It sounds like one of them has come loose, because if the receiver only has one working cable coming in from the dish it can only do one thing at once- you can only record one show at a time with one cable. You can also go into the receiver's setup menu and run a system test, which will help you diagnose the issue.
Feb 08, 2009 | Directv (R10) DTV Receiver / 70-Hours...
My pansat3500 does not work on directv
Hi there you can go to this link http://www.pansat3500sd.com/ then contact them it is the official website of pansat3500sd..
Please rate thanks God bless
Nov 10, 2008 | Panasonic DMR-ES10 DVD Recorder
Copying recorded footage from the DWD490RE without DirectTV Service.
Make sure the cables that used to run from the satellite are still connected even though u dont have directv, the unit will still download any software updates it needs. if the dish is no longer available, wait until the dvr is trying to aquire satellite info before u hit the menu button. it will allow u to watch saved recordings while it searches for a signal. Also you can plug a dvd recorder to the unit and transfer recordings to dvd
Oct 21, 2008 | RCA DWD490RE
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Reciever Not Recording
Turn off the receiver, unplug the receiver, wait 30 seconds, plug it back in, and go through the setup again. This hard restart clears the memory and restarts the DVR software(clears any software glitches) This should fix this problem assuming that your satellite signal is good. Check that during the resetup. Most transponders will show between 70 to 100 signal strength. (Minimum is 70 for error free reception) Several transponders will show 0 as they are dead on the satellite, and not a receiver problem) If your satellite signal is in the 70's or less, you either live in Maine or you may need to realign the dish or something is blocking the signal like a tree or bush growing that is partially blocking the signal causing the signal to drop out(partial recordings)
Mar 04, 2007 | Directv HR10-250 DTV Receiver
iLO DVDR05 DVD Recorder Logo
172 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
