Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
No internet sites reachable, nothing appears to be wrong
New motherboard, ASUS P5GC-MX/1333. Built in Atheros L2 Fast Ethernet 10/100 NIC. 3GB RAM. Windows XP Pro/SP2.
Drivers for NIC load properly. No obvious hardware or software issues found. Receives NAT IP address from wired router. Other systems on same router accessing internet with no problems. This system cannot even ping my ISP's DNS servers by IP address. No replies.
  • Tim David
    Tim David Nov 23, 2008
    Did both suggestions, but to no avail. Added a non-MB based NIC (Kingston) and it works fine, so there is either something wrong with the MB based NIC hardware or the driver.
  • Anonymous Nov 30, 2008
    I have the same problem with P5GC-MX.
  • 781 Answers
Have you set it up for network through windows network setup
also check network name the same (I had one that i thought was correct and one letter in network name was different and would not connect)
Posted on Nov 19, 2008
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Apr 01, 2017 | ASUS Computers & Internet
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
I got a PC board P5GC-MX /1333 i have search for Ethernet Controller over internet but i cannot search to download to installed on to my new hard disk The once that i try cannot pick my Ethernet...
Check out the AsusTek Support Site.
From the "Download" Tab, select your OS to download LAN (Atheros L2 Driver) drivers. Just unzipped the downloaded files to alocation on your PC & run the installers.
Hope it helps.
Jun 11, 2011 | Computers & Internet
I have asus p5gc mx 1333 motherboard but I dont have the ethernet driver where can i find. can you kindly send me the link
hello rupan_nick
go to asus web site
http://support.asus.com/download/download.aspx?SLanguage=en-us
select download
select your item (lan)
select model no( P5GC-MX)
select os what ware you using
this should fix your problem
Jan 19, 2011 | ASUS P5GC-MX/1333 Motherboard
I remove ethernet controller from "add/remove hard...
You can download the LAN driver to asus website. Just click on the link below
Download Here
*Product Type: Motherboard
*Select Series: Socket775
*Model: P5GC-MX/1333
*Operating System: Depends on your OS
*Chose which driver you want to install and download.Thanks for using Fixya.
May 20, 2010 | ASUS P5GC-MX/1333 Motherboard
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
319 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
