Question about KEF Audio PSW 1000 Subwoofer
Weird burbling muffled squeak noise!
When my sub is not in use it makes a strange burbling noise which doesn't seem to come from interference - could it be the power caps? theres 2x 10000uf and two smaller 300uf near the outlets. also it does sound wooly and not tight but that could be my room - it's only small! The phase shift pot minimises it at 180'. I don't know how old it is-? bought it on ebay a year ago. It started making the noise two months after i bought it. serial bar code is 992071g. I hope there is a solution, can you help? Kind regards, Duds
  • MarsCHAN Feb 13, 2009
    I have the same noise problem with the KEF PSW1000. Got it repair at high cost but it happens again.
    Can any one help? I try to replace the 2x 220uF 16V cap, the relay, the problem is not solved.
    Problem Solver:
  • 14 Answers
You can simply and easily replace 3 capacitors on the main amplifier board (c58 - 47uF 63v or 100v) + (c52 & c53 - 220uF 25v) but stand them away from the board on the length of the capacitor leads to prevent them from absorbing heat from surrounding hot components (with heat shrink tubing to prevent shorting)
these are usually the cause of most problems with KEF PSW subs, as for it sounding wooly, this is just the way it is, mine is the same.
Posted on Nov 07, 2011
SOURCE:
Strange noise from mk17
Scuba pro has repair facilities everywhere they can fix this problem with a annual service kit.
Feb 26, 2013 | Scubapro MK17/S555 Regulator
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
My LG Front-load dryer is making a loud noise during the drying cycle. If i press on the lower left front panel - the noise is muffled quite a bit. Model # DLE5977
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gfg
Sep 27, 2010 | LG DLE5977 Electric Dryer
Why is cooling fan making weird noises
Depends on what the weird noise is...kind of a squeak? Fan bearing are going out....clicking or dragging sound? the fan blade is hitting something....
Feb 08, 2010 | Toshiba Satellite A45-S130 Notebook
I have the klipsch sub-10 subwoofer, making noise after use
it sounds like the sub is rubbing in the voice coil.
put the speaker in upside down to what it was before.
sometimes that extra bit of downward pull is enough to offset the error.
There are speaker reconing experts out there but it is cheaper to replace the sub itself.
the sub can be replaced for sure.
Jan 13, 2010 | Audio Players & Recorders
Squeaking on 1999 toyota corolla
Throughout my experience with Toyota's I have found that several times the hubcaps have made some weird noises. Try removing your hubcaps and driving your vehicle. If the noise still persists please let me know and I can ask u some questions and try to help you with your problem.
Aug 11, 2009 | GMC Jimmy Cars & Trucks
My dryer just started to make a weird squeaking noise
heatman101
dhgj
Jan 27, 2009 | Maytag MDG6000 Dryer
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Subs make a noise
If your sub or its amplifier is placed too close to the transmission box, this situation can cause interference. I suggest that you buy a ground loop isolator or an RCA filter. If the problem is about grounding, then you have to buy a ground loop isolator. Otherwise, an RCA filter can solve your problem. First of all, the problem has to be diagnosed.
Jul 04, 2007 | Infinity BASSLINK Car Subwoofer
KEF Audio PSW 1000 Subwoofer Logo
281 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
Axel Gringmuth
 Grubhead
Grubhead
Vernon Taylor
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
