Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Memory card error
When I turn on my S400 it reads memory card error on the screen.I have tried a new memory card and it still reads the same thing.If anybody has any thoughts on what the problem might be that would great!
This repair is covered by a mass recall by Canon. See their website for details. No charge for out of warranty
Posted on Mar 14, 2007
Canon will repair this problem at no cost. Skip over to their website for info. Out of warranty is OK!
Both I and my son have IXUS 400's bought about 3 years ago with this problem. Reformatting cures sometimes for a short time but basically both cameras are useless. Neil
Posted on Jan 29, 2007
SOURCE:
I am getting a "Memory
Its a very common problem with S400,S410 and some others.
As a case study, see the following error message on the Canon IXUS 130 when trying to view some photos previously stored in the memory card SDHC
"Memory Card Error"
Every single photo stored on the memory card becomes inaccessible after the above error message. In addition, no more photos can be stored on the memory card. In short, the card can not be read or written.
Cause:
The above error message that makes all the pictures inaccessible is mainly caused due to corruption of the memory card. Reasons why you are responsible for the above error message is virus infection, interrupted read / write operation, and human error.
Resolution:
The resolution for the above error message is the format of memory card into the camera. The process erases all data previously stored and allows you to save the new data. While the format is a good resolution for users who do not require the old data, it is fatal to users such as photographers, detective agencies, etc, to save critical data on your memory card. However, the formatted data recovery day is now an easy process. It is therefore necessary to use an advanced part of third parties. A tool for image recovery is readily available on the Internet by one click.
Data Recovery is an application of high-end recovery that recovers data from almost all formats SDHC Card, XD and MMC. The read-only photo recovery tool also allows you to restore data in the defined location. The software runs on Mac OS X and Windows.
Check this link for additional details: Simple Fixes for SD "Memory Card Locked" or "Memory Card Error"
Hope helps.
Jun 07, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
I have a hp psc 2355 printer everytime i insert
I had the same problem with my HP L7590 All In One. After trying a number of things to reset nothing worked. Then I tried this just as a last resort and it worked.
Insert the/a memory card( it will tell you that you can only use one card at a time).
With the card still in turn off the printer using the power button.
Wait for 30 seconds then turn power on again.
The screen should say reading card. So wait for it to finish reading and all should be fixed.
If this does not work, try again using a different card.
good luck
Send me Kudos if it works.
Oct 25, 2009 | HP PSC 2410 All-In-One InkJet Printer
My Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Sep 12, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Blury lcd screen, but now sometimes the screens black. I also have a memory card error
Canon had manufacturing issues regarding memory errors and also the CCD. They will fix this free of charge. Even if the camera is out of factory warranty. Contact Canon. They were very helpful and fixed the same issues on my S400
Aug 11, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
S400 memory card error. Turn on camera - display "NO IMAGE MEMORY CARD ERROR". Can not take pictures, can not display pictures. Have several memory cards - same message, different cards. If the camera...
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Feb 21, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Nikon 4600 coolpix
Hello, Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
Dec 08, 2008 | Nikon Coolpix 4600 Digital Camera
Memory card error
The clock button battery inside the camera has expired. Canon will fix this for free (or if you want, will send you a replacement battery with instructions on changing it out). Read the following recall advisory, then contact Canon at 1-800-OK-CANON:
Jun 20, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card error
On the old Powershot S400, this error was caused by a dead internal "clock" button battery. Fixing it required simply replacing the battery. But before you attempt to do that, would first suggest trying a different memory card.
Jan 20, 2008 | Canon PowerShot A540 Digital Camera
Memory card error
Solution:
1 set date to 31-12-2030 23h59 and switch camera off.
2 wait two minutes, day will be 01-01-2003 and camera asks you to set the date
3 take away memory card
4 set the date to today
5 insert memory card again
Now your error should be solved.
Sucess, Jonny
Nov 09, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
