Question about Gateway 506GR PC Desktop
WHERE CAN i BUY A NEW CASE FAN FO GATEWAY 509GR
WHRE CAN I BUY A CASE FAN FOR 506 GR GATEWAY
  • 1944dale132 Nov 19, 2008
    WILL THIS FAN NOT RUNNING PREVENT COMPUTER FROM STARTING???
    Sergeant:
    Champion:
  • 251 Answers
U can pick one up at a local computer shop do not by one online for tiger direct they have a tendence of sending the wrong parts
Posted on Nov 25, 2008
    Genius:
  • 1,124 Answers
You can buy a fan here:
http://www.tigerdirect.ca/applications/SearchTools/search.asp?keywords=Ultra+X-Wind+CPU+Cooling+Fan&image12.x=13&image12.y=22
Your motherboard is Socket 775 (your fan must be socket 775)
Posted on Nov 19, 2008
  • Pablo Csaky
    Pablo Csaky Nov 26, 2008
    Why you rated my solution as innapropiate?
    Please explain or change your rate!
Gateway mfatxnin es2 300x cel
Hello! Please make sure your CPU fan, is dust-free and obstacle-free, if this is not the solution you may unfortunately have to buy a new CPU Fan. - Old Gateway by Acer worker.
May 18, 2014 | Computers & Internet
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
Have a gateway 506 gr windows xp.. picked up a
If you didn't create recovery disks when you got the computer, you will need to contact Gateway for them.
I would question the supposition that you have a virus. If you do, you can usually at least get into safe mode. I would suspect a hardware problem in your case.
Feb 20, 2010 | Gateway 506GR PC Desktop
Gateway 831GM Eratic Fan Noise
This can be caused by several things:
1. Bad temp sensor
2. Bad voltage, but that will usually cause the whole system to restart
3. Too low maximum temp setting inside the chassis(setting is in bios), often denote as max case temp.
One way to bypass the problem is rig the fan to a molex adapter with a variable voltage molex to 2/3/4pin fan connector and adjust the speed to the maximum quiet setting.
The 831's did run a bit warm so if the case temp setting is set to low it will fluxuate quite a bit. Try adjusting the max case temp up around 50c just to see if that does it, if it does either use the variable voltage dial solution or add a second case fan that's always on, prefferably a low RPM running direct off molex so it will reduce the average temp and therby the need of the monitored case fan to rev up.
Chris
Armor-IT
Apr 24, 2009 | Gateway 831GM PC Desktop
Gateway 420 gr needs an upgrade hard drive
Yes you can upgrade the hard drive of this computer , you just need to get a Serial ATA hard drive from any electronic / computer store nea you like best buy or some store like amazon and others..
Jan 21, 2009 | Gateway (M520HD80G) Hard Drive
Replacement Fan And Heat Sink For 500 GR
Remove the heat sink and fan, take it to any computer shop and they will give you compatible replacements
May 17, 2008 | Gateway 500GR PC Desktop
Monitor keeps shutting off
it is a "CPU THERMAL SHUTDOWN"
Make sure the CPU fan is working. If there are any other fans on the motherboard, make sure they are working.
Make sure the case fan(s) are working and that there is no obstruction to the airflow into and out of the case.
Your CPU fan may be broken and you will need to buy another one.
Was this solution helpful? Show your Appreciation by rating it:
Feb 10, 2008 | Gateway FPD2275W LCD Monitor
Gateway 506GR PC Desktop Logo
117 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
