Question about KitchenAid Architect Series KEBC208KSS Electric Double Oven
Rattleing noise when either oven is turned on
When I turn on either of the ovens there is a rattling noise from a fan. This continues after turning off the ovens, until they have cooled off.
  • 1 more comment
  • Brian Chatfield Jan 02, 2007
    Can I access this back panel without pulling the stove out of the wall?
  • RobinsonAM Jan 13, 2008
    Cooling fan vibration noise until oven cools
  • Anonymous Oct 24, 2008
    Same exact problem with KEBK206 double oven. Obviously the cooling fan, but how to access? From the front panel or remove oven from opening?
    Russ
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
SOURCE:
Whirlpool built-in electric single oven makes a whining noise after it is turned off?
Most of them are equipped with a cooling fan designed to keep the controls from melting... Once it is warmed up, the fan runs until the fan thermostat cools enough to power it off... Cooling Fan W10127321
Jun 29, 2016 | Whirlpool Ovens
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Why is the oven fan making a rattling noise
I do not no the specific model you have but chances are that the noise you are hearing is the bearings(or brass bushings) are going out in your fan motor. Which in turn allows the shaft of the motor to not remain true and rattles. In laymen's terms, you just need a new fan motor. I hope this helps. "Be Easy!"
If you need further help, reach me via phone at https://www.6ya.com/expert/greg_012fb269876eb4b0
Feb 25, 2015 | Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Since it is new contact the people that sold you the oven for warrenty repair.
Nov 18, 2014 | Caple Ovens
Main oven motor cover
Why not secure the fan cover?
Jun 22, 2013 | Ovens
Hi, I have a Zanussi ZBF
Your fan is catching the element which has distorted with heat
Oct 04, 2017 | Zanussi Ovens
The fan continues to run. How long and will it automatically shut off?
The fan you refer to should be the fan in the oven cavity. It removes hot air from the oven cavity and expels the air out the front of the oven. Once the oven is turned off the fan will continue to operate until the oven cavity has cooled sufficiently. It may run for 10 to 15 minutes and will turn off by itself.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
2,055 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
